the thing runs rough till it warms up
Old 09-30-2010, 05:54 PM
billfish1's Avatar
billfish1
billfish1 is offline
when i first crank the truck up in the morning it runs rough for about 10 mins. till it warms up { i am in alabama and it can be 90 degrees outside}. the best way to describe it is that it acts like its not getting enough fuel and spits and sputters. if i give it the gas it goes no where. i carried it to the ford dealer and they said it was the ficm. i look on line here and saw how to check it. never did it go below 46 volts. but i want ahead and pull it out and had the joints re solider as advised in here. did the check again and still always have 46 volts. but it still runs the same. anybody have any ideas. 06 model f350 6.0 liter
Old 09-30-2010, 06:49 PM
69cj's Avatar
69cj
69cj is offline
We have absolutely no idea what truck you have and that does make a big diff!!
Old 09-30-2010, 06:50 PM
cheezit's Avatar
cheezit
cheezit is offline
you need to check the ficm while cranking, while at idle and at 2k rpm. it may take a min or two to start droping. or you may have an injector stiction issue.
Old 09-30-2010, 07:50 PM
billfish1's Avatar
billfish1
hey sorry about that. i have a 06 model f 350 with a 6.0 liter. i have checked the voltage all different way and the voltage never drops. is there something else in the ficm that maybe causing the problem
Old 09-30-2010, 07:54 PM
sandmanf250's Avatar
sandmanf250
sandmanf250 is offline
see if your icp is leaking oil.
Old 09-30-2010, 08:14 PM
69cj's Avatar
69cj
69cj is offline
If an early 06, could be stc fitting.
Old 09-30-2010, 09:59 PM
jetpilot1's Avatar
jetpilot1
jetpilot1 is offline
rough running
If it runs ok after the rough warm up, I'd suggest you may have injector stiction. I would try a oil change with synthetic 5W-40 and with some Hot Shot's Secret. If it is stiction, that's your best shot at cleaning it up without an injector change.
Explodin' Bryan
11-23-2014 09:15 AM
mwkobe
08-31-2011 08:15 PM
mustang9701
05-05-2011 04:54 PM
dnroberts
03-09-2011 02:15 PM
Quick Reply: the thing runs rough till it warms up
