the thing runs rough till it warms up - Ford Truck Enthusiasts Forums
Old 09-30-2010, 06:54 PM
billfish1 billfish1 is offline
billfish1 is starting off with a positive reputation.
when i first crank the truck up in the morning it runs rough for about 10 mins. till it warms up { i am in alabama and it can be 90 degrees outside}. the best way to describe it is that it acts like its not getting enough fuel and spits and sputters. if i give it the gas it goes no where. i carried it to the ford dealer and they said it was the ficm. i look on line here and saw how to check it. never did it go below 46 volts. but i want ahead and pull it out and had the joints re solider as advised in here. did the check again and still always have 46 volts. but it still runs the same. anybody have any ideas. 06 model f350 6.0 liter
Old 09-30-2010, 07:49 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
We have absolutely no idea what truck you have and that does make a big diff!!
Old 09-30-2010, 07:50 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
you need to check the ficm while cranking, while at idle and at 2k rpm. it may take a min or two to start droping. or you may have an injector stiction issue.
Old 09-30-2010, 08:50 PM
hey sorry about that. i have a 06 model f 350 with a 6.0 liter. i have checked the voltage all different way and the voltage never drops. is there something else in the ficm that maybe causing the problem
Old 09-30-2010, 08:54 PM
sandmanf250 sandmanf250 is offline
sandmanf250 is gaining momentum as a positive member of FTE.
see if your icp is leaking oil.
Old 09-30-2010, 09:14 PM
69cj's Avatar
If an early 06, could be stc fitting.
Old 09-30-2010, 10:59 PM
jetpilot1's Avatar
jetpilot1 jetpilot1 is offline
jetpilot1 is starting off with a positive reputation.
rough running
If it runs ok after the rough warm up, I'd suggest you may have injector stiction. I would try a oil change with synthetic 5W-40 and with some Hot Shot's Secret. If it is stiction, that's your best shot at cleaning it up without an injector change.
FICM vs. injectors PROBLEM DIAGNOSED Explodin' Bryan 6.0L Power Stroke Diesel 18 11-23-2014 10:15 AM
New Batteries Installed. xaviar 1999 to 2016 Super Duty 0 10-09-2012 11:25 AM
runs rough till warm mwkobe 1999 - 2003 7.3L Power Stroke Diesel 3 08-31-2011 09:15 PM
New here with a question mustang9701 6.0L Power Stroke Diesel 8 05-05-2011 05:54 PM
runs rough, no power dnroberts 6.0L Power Stroke Diesel 5 03-09-2011 03:15 PM
Tags
2005, 60, bad, cranked, diesel, f250, ford, hot, powerstroke, rough, runs, til, till, warmed, warms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
