Ball Joint won't take grease - Ford Truck Enthusiasts Forums
Old 09-30-2010, 12:05 PM
timmygyu timmygyu is offline
timmygyu is starting off with a positive reputation.
Hi all,
I'm having an issue greasing a ball joint in my bronco--it's a '90, 351, eddie bauer, if that helps. The BJ in question is on the front, passengers side. Before I attempted greasing I jacked up the vehicle, as I read that it helps to take the weight off the BJ.
At first the grease was coming out at the zerk. Upon closer inspection, I could see that the zerk fitting was crossthreaded. I removed the fitting, and tried to pump grease through it. Worked fine. I then managed to rethread it correctly, so that the grease doesn't spew out. In fact, now I can't pump in any at all. I read that the zerk can be screwed in too far, so I tried backing it off a good bit. Same thing: no grease in, and no grease out. I found a cutaway of how a ball joint is built, and after looking at it, I'm wondering if it's possible for the joint to rust up and block the grease from going into the cup. Here's the picture, for reference(click it to see full-sized version):
Anyway, as I know WD-40 and ducktape can fix just about anything, I was thinking of squirting some of the former under the rubber cup to try and break up any interior rust that might be blocking the grease from going in. I'm out of ideas otherwise. Am I on the right track here, or am I headed for trouble?
Thanks in advance,
Tim
Old 09-30-2010, 03:32 PM
helirich helirich is offline
helirich is starting off with a positive reputation.
Most likly the hole where the grease nipple threads is clogged. I would remove it and stur a pick in it. Then wash with WD.
Old 09-30-2010, 04:46 PM
American Thunder's Avatar
American Thunder American Thunder is offline
American Thunder is gaining momentum as a positive member of FTE.
What he said. And always wipe off the zerks carefully before greasing, too.
Old 09-30-2010, 05:21 PM
I've already tried a pick; didn't seem to be anything obstructing it. Also cleaned the fitting. So WD won't hurt anything? I guess that's my next step.
Cheers,
Tim
Old 09-30-2010, 07:17 PM
b4hntn b4hntn is offline
b4hntn is gaining momentum as a positive member of FTE.b4hntn is gaining momentum as a positive member of FTE.
On mine I have to turn the front of the tire outward and stick my head inside the fender to see well enough to get the grease gun on straight to grease the upper BJ.
Greasing NEEDLE bearings (not accessed by ABS hole) WITHOUT removing unit bearing - Write Up & PICS Y2KW57 1999 - 2003 7.3L Power Stroke Diesel 20 02-19-2017 05:00 PM
2005 4x4 Excursion, new ball joints... and the zerk fitting dilemna JohnnyAirtime Excursion - King of SUVs 8 04-14-2016 05:43 PM
Greasing zerk fittings 4.9LOldFordTruck 1987 - 1996 F150 & Larger F-Series Trucks 6 01-20-2016 04:38 PM
Ball Joints, Grease-less?? Keny1 1968-2013 Full Size Vans 7 03-18-2014 06:13 AM
Moog ball joint zerk missing Budman1962 1999 to 2016 Super Duty 13 03-20-2008 11:50 AM
Tags
1978, accept, ball, balljoint, bronco, f150, f350, greas, grease, greasing, greese, joint, joints, upper, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
