p0171 and p0174 on 5.4 supercharged (SOLUTION) - Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Old 09-30-2010, 05:36 AM
EFM EFM is offline
EFM is starting off with a positive reputation.
I got the codes p0171 and p0174 on my 03 5.4 Supercharged Harley. I had no drivability issues at all but after cleaning my MAF the codes came back. SOLUTION: I didn't hear any hissing but went ahead and followed the PCV hose that goes to the back center of the engine and removed the
90 degree rubber the connects to the block and it was indeed colapsed. It is very hard to get to especially if u have large arms you may need the assistance of a skinny helper. I did use a spark plug wire boot and it seems to work well................. I just wanted to share this info because after many hours of research I could not find anything for the supercharged engines. I hope I can at least help one person and save them a few $ and alot of headaches. Thanks for listening!
<!-- / message -->
<!-- controls -->
Old 09-30-2010, 08:59 PM
lurch lightning lurch lightning is offline
lurch lightning is starting off with a positive reputation.
Code's
Code's are Lean Bank 1 and 2, I have seen Several Problems cause this Vacuum leak, I asume you pluged the lower part of the intake behind engine These crack all the time,( Very Hard to get to) O2 sencor can cause this,Good Luck
Old 10-01-2010, 10:50 AM
King Leo's Avatar
King Leo King Leo is offline
King Leo is starting off with a positive reputation.
I have a 03 Lightning myself and found the PCV valve on the passenger side valve cover. I don't have any problems or anything but wanted to say that, with supercharged engines, you would hope that the PCV valve itself is a bi-directional unit.
Otherwise, unless you have an oil recovery system, there would be MORE oil comming up into the intake than normal. A normal ammount is just a slight sheen coating of oil inside the intake and around the throttle body.
Motorcraft EV-233 PCV valve is stock on the 03 Lightnings and IS bi-directional. They also come with a 45 degree boot that you can take off. I installed PCV valve w/45 degree boot and it does calapse. Just remove the boot and install it straight up (2003 Lightning here) and all is well.
King Leo
E250 Cylinder 5 Misfire MisterZ 1968-2013 Full Size Vans 10 05-13-2014 06:30 PM
01 e250 p0171 & p0174 dafish13 1997 - 2003 F150 2 06-12-2012 09:55 PM
p0171, p0174, p0401 ford E350 trouble flyinghi3 Modular V8 (4.6L, 5.4L) 0 06-06-2011 06:34 PM
Vacuum hoses iilijah 1997 - 2003 F150 4 12-25-2010 05:18 AM
99 4.0 Ranger CEL loss of power low gas mileage Danimal1481 Ranger & B-Series 2 02-21-2010 02:44 PM
Tags
2003, 54, 98, code, davidson, engine, f150, ford, harley, lean, p0171, p0174, saleen, superchared, supercharged
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
