What is the best Electric Cooling Fan kit for a cheap price - Ford Truck Enthusiasts Forums
Old 09-29-2010, 09:13 PM
BlitZ_ BlitZ_ is offline
BlitZ_ is starting off with a positive reputation.
Looking to remove my HP robbing fan clutch and go electric. I want one that is make spec for my 2003 king ranch 5.4 4x4. I dont want to drop a whole lot of money but I dont want a peice of junk either.I want it to last me for a long time with out any problems. Any advice is much appreciated, thanks in advance.
Old 09-30-2010, 08:17 AM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
Quote:
If you want a fan that'll last, and actually move enough air to reliably cool the engine, then you do not want any of the aftermarket "kits". You'll need to fabricate your own from a good OEM fan, and modify the truck's existing fan shroud to house that OEM fan.
JL
Old 09-30-2010, 08:29 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
Any suggestions Johnny on what fan to use and control system? As well as best installation spots?
Been interested for awhile, i think id rather build my own as well.
Old 09-30-2010, 08:45 AM
The best fan, IMO (with experience to back that opinion up), is the '94-'97 Tbird/Cougar fan. It's a 2-speed fan, so you can use the low speed for everyday cooling, and have an high limit temp switch to control the high speed in the case that you need it. That's what I've used on the last 2 that I've done e-fans on, and those fans work. I use an adjustable thermostatic controller that has an A/C input to turn the fan on when the A/C compressor is running, and use a high amp relay for the fan itself. The OEM fans will literally melt those little cube relays that most all of the fan controller use. I always get the fan controller that has the threaded sensor so you can tap it into direct coolant flow-those that have the "probe" that you wedge into the radiator fins are not very accurate and are not reliable. I'll dig up the part numbers of the controller and such in a bit and post them later.
JL
Old 09-30-2010, 09:22 AM
Awsome, thanks johnny. I know where there is a cougar in a junkyard near here. Might have to go see what they want for it.
Old 09-30-2010, 09:24 AM
Make sure it's a '94-'97 4.6L. I dunno if the 3.8L cars have the same fan.
JL
Old 10-01-2010, 07:59 PM
Im not going to rig anything up I want a direct bolt on kit thats spec for my truck. If I have to spend a little extra money to get a good one then I will but im not doing any kind of fabrication on this mod its just not worth that much effort to me.
Old 10-01-2010, 08:03 PM
Then be ready to buy substandard aftermarket garbage fans that are very overpriced, do not move anywhere near the air that they claim, and fail with startling regularity.
JL
Old 10-01-2010, 08:08 PM
well if you want to do the fabing ive got the $$$ 03 f150 king ranch 5.4L 4x4
Old 10-01-2010, 08:10 PM
I'm not here to sell anything, but I can tell you what you need to do it yourself. You'll be much happier, and knowing that you did it yourself is worth alot.
JL
Old 10-01-2010, 08:19 PM
Here's the fan controller I like to use:
Derale Cooling Products 16749 - Derale Performance Deluxe Adjustable Controllers with Pipe Threaded Probes - Overview - SummitRacing.com
You'll need a high-amp relay to actually power the fan-use the relay on the fan controller to trigger the high-amp relay.
Here's the high-amp relay I like to use:
Terminal Resolutions has Wire Terminals, Automotive Wire, Battery Terminals & Electrical Supplies
It can handle the startup and continuous load from the fan-you'll need two of these if you want to run the high-speed with a thermal switch or with a manual override switch.
JL
Old 10-01-2010, 08:33 PM
ok post the ebay links away
Old 09-03-2013, 05:36 PM
Dr.Decoy Dr.Decoy is offline
Dr.Decoy is starting off with a positive reputation.
Hey Johnny Langton, I am trying to do this mod on my 2001 Ford F-150 5.4L Crew Cab. The link you gave for the High Amp Relay doesn't seem to be working. Can you repost it for me? Also do you have any photos that show your mod? How you mounted everything up? Thanks!
body lift fan shral billyrayf150 Offroad & 4x4 3 12-24-2015 09:49 PM
How to determine cooling cfm? bigdan1979f-250 1973 - 1979 F-100 & Larger F-Series Trucks 6 04-24-2014 11:01 PM
Electric fan gad4wd 2004 - 2008 F150 1 04-17-2013 05:46 AM
.......electric fan????? traxx808 1987 - 1996 F150 & Larger F-Series Trucks 21 05-13-2010 11:01 PM
Electric Fan Clutch mudmagnet 1994.5 - 1997 7.3L Power Stroke Diesel 7 01-10-2010 09:05 PM
Tags
2001, 2005, 2006, 97, cheapest, cooling, elecrtic, electric, f150, fan, fans, ford, kit, lightning, make
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
