ambulance brake lights....blink..blink..ON - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 10-01-2010, 07:17 AM
Copedawg's Avatar
Copedawg Copedawg is offline
Copedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant future
This is true, Jim! It would look like a flippen circus at a stop light/traffic jam and take away from the emergancy vehicles that makes them stand out. Good point!
  #32
Old 10-01-2010, 08:56 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is online now
Brown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud of
I have to press on my pedal pretty hard just to get mine to come on.
  #33
Old 10-06-2010, 05:11 PM
Copedawg's Avatar
I just called katech in regards to my e-mail I sent last Friday. I talked to Alan who "did not see your e-mail" So gave me his direct e-mail and I will address him in the morning. In the small talk he said the new Mercedes has the blinking standard and also said it was legal as long as it did not blink for more than 3 seconds. He was very nice with a lot of "by the way" facts. So I will ask my question tomorrow and see how he replies.
  #34
Old 11-28-2010, 08:34 AM
coolarmybrat coolarmybrat is offline
coolarmybrat is starting off with a positive reputation.
Smile
In regards to the third brake lights blinking and then comes fully ON...there is "add on" module that is available for almost, if not all, vehicles out there. Let me post a clip so that I do not bore you and I might be OFF TOPIC (and be banned forever ).
  #35
Old 11-28-2010, 08:56 AM
Hussler's Avatar
Hussler Hussler is online now
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
On this site we are OFF topic more than ON topic so I would not worry about it.
  #36
Old 11-28-2010, 09:53 AM
Jim's right... this forum almost always turns to off topic/hijacking at some point.
  #37
Old 11-28-2010, 06:46 PM
trike1946's Avatar
trike1946 trike1946 is offline
trike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud of
You can buy a light bulb for motorcycles that replaces the stock bulb with one that is round, maybe 1 1/2 inches across. It is all LEDs. When running they go in circles, then when you hit the brakes they blink 3 times and then stay on. You can also get some LEDs that will just blink then stay on. I have had both on my bike and no problems with inspections or the state or local police. And NJ is really a problem with police.
Or if you stop at any place that makes ambulances you can pick them up. The problem is that stock lights in ambulances are not cheap. The bulbs are about $20 each. So I converted mine to normal as they went bad. But mine are older. The newer trucks have even more costly lights from what I hear.
  #38
Old 11-28-2010, 09:06 PM
SF-ESS's Avatar
SF-ESS SF-ESS is offline
SF-ESS is starting off with a positive reputation.
A lot of us in the motorcycle community have out bike brake lights flash. I believe that as long as your brake lights do not flash in a wig wag or side to side manor they are legal but check your state you can build one yourself by following this Motorcycle Brake Light Flasher. I realize it says motorcycle but the values are the same as it was pulled from an automotive original schematic. parts are easy to get from you local radio shack or on line. You can buy a flash pack for around $150.00. to get the same results. Going to led lights just requires a resistor in line to off set the current load so your flashers will not speed up again same issues for bikes going to led systems HD resistors are around $10. Hope this helps
  #39
Old 11-30-2010, 03:46 AM
powerstoked!'s Avatar
powerstoked! powerstoked! is offline
powerstoked! is starting off with a positive reputation.
FYI guys, if you have an automatic trans, then you have to add a load compensator inline with the brake lights if you change to LED. For example, our tail lights, which are 3157LL bulbs... at 12.8VDC have a 26.9W or 2.1A load... a compatible LED 3157 only has about a 3W or .25A draw. So you have to wire in a 6ohm 50 W resistor in the brake light circuit so that the computer doesn't think that a bulb is out.
Reason for all this hokus pokus is because out torque converter lockup circuit operates using the brake light signal. If the TC lockup circuit senses a closed circuit, then it won't lock the TC because it thinks you are on the brakes. With the low internal resistance of an LED, the circuit appears to be closed to a clumsy circuit built in the mid 90's, but with the addition of the resistor it will operate correctly. Here is a link to help with visuals and such:
http://www.superbrightleds.com/pdfs/...istor_info.pdf
our turn signals use the same light circuit that the brake lights do, so wiring the resistor in correctly will solve fast flash and TC lockup issues. For those of you with manual trans', all you are going to deal with is a fast blinker because the flasher relay thinks a bulb is out so it flashes real fast due to the low draw circuit... so it would benefit yall to read this too so that you can fix your blinky problem! hah! hope that helps ya somehow in reference to the LED upgrades yall were talking about. Oh and if you do decide to get the LED bulbs to upgrade, make sure you buy the 360 deg dual contact 3157 replacement bulb towers like these:
45-LED Tower Type 3157 Bulb Specifications
make sure you order the red ones... reason for buying these in particular is so that the bulb tower projects light throughout the reflector dish inside of the taillight housing and lights the whole housing instead of just having a hotspot in the center from outward facing led's only. Here is an example of the type of resistor you need to buy:
Load Resistor Kits
Any q's on this tech spec craziness, feel free to ask guys, and I hope I can at least save one person a headache down the road.
ATTENTION: I AM NOT REPPING OR SUGGESTING THAT ANYONE BUY SUPERBIGHTLED PRODUCTS, NOR AM I REPPING THEM AS A DEALER, THEIR WEBSITE WAS JUST HANDY TO HELP EXPLAIN AND GIVE EXAMPLES AND PICTURES
  #40
Old 11-30-2010, 10:23 PM
IowanStraight6's Avatar
IowanStraight6 IowanStraight6 is offline
IowanStraight6 is starting off with a positive reputation.
I know what your talking about our tow truck at work have them when the brake is applied they flash twice quickley then stay on i think those would be sweet to have. But the page jim has looks like they would be annoying as hell them flashing all the time i would think its a cop
"WHO ya gonna call? (Ghost Busters!!) seattle smitty 1968-2013 Full Size Vans 16 12-24-2014 12:26 PM
parking brake cable ... ambulance package ? joey2fords 1987 - 1996 F150 & Larger F-Series Trucks 4 08-25-2014 08:59 PM
1986 F150 Brake Light/Blinker Mix Up ooxneozoo 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 06-22-2014 08:25 AM
turn signal problems boo-yaa138 1967 - 1972 F-100 & Larger F-Series Trucks 16 03-10-2014 12:48 PM
Retired Ambulance Stopping Distance Problem DaedalusEco Brakes, Steering, Suspension, Tires, & Wheels 1 02-13-2014 08:42 AM
Tags
350, ambulance, blink, blinking, brake, brakes, chace, ford, lamps, light, lights, pictures, stop, style, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
