'86 F150 heater core - Ford Truck Enthusiasts Forums
Old 09-29-2010, 08:22 AM
86stepsideF150 86stepsideF150 is offline
86stepsideF150 is starting off with a positive reputation.
'86 150 302 stan. cab 4x4. I have been observing the symptoms of a heater core going bad for a while now, and it is definitely time to replace it with winter coming up. I read the thread about heater core brands, and I must say, I am a little scared now! I certainly do not want to replace the core every year from here on out. I suppose regular maintenance can prevent that, but I would still like to use the best quality part of the poor selection of available parts. Has anyone established which part is the BEST choice?
I got a lot of mixed signals. Some say NAPA is the best option, I also read that there are really only a couple manufactures remaining, and the quality of a new core is poor no matter where you get it or what brand name it is called. So, what is the conclusion here? I won't bypass it, I need my heat!
Old 09-29-2010, 08:38 AM
parr4 parr4 is offline
parr4 is starting off with a positive reputation.
I seriously doubt there are more than 2 manufacturers of replacement cores anymore for older vehicles. I've replaced one core in the 29+yrs I've had my truck. AZ was the store I bought from. I'm not a big fan of AZ, but.... Most-important is cooling system maintenance. Replacing any lost coolant with distilled water and a good brand of coolant changed at recommended intervals will go a long way in keeping a heater-core and a radiator-core reliable. As in buying any part, call local stores and check RockAuto.
Old 09-29-2010, 09:55 AM
Grubbworm's Avatar
Grubbworm Grubbworm is offline
Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.
I replaced my heater core once, probably 15 years ago. I got it from here Marietta Radiator Distributors | 501 Glover St. Marietta, Georgia 30060 | 770-428-5900
I have had no problems since. I also had to replace my radiator once, probably 5-10 years ago. I purchased it from the same place. Both the radiator and the heater core were Modine. I paid a little more there, but they both appeared to be of a better quality than anything else that I looked at locally. I would suggest going to a place that sells good quality parts to the professionals, maybe a specialty house, and ask them as many questions as you can get away with. The place that I got mine works only on radiators and air conditioners, and they also sell the parts that they use. They have been in business and highly recommended for many years, because they are very good at what they do.
Old 09-29-2010, 10:44 AM
smashclash smashclash is offline
smashclash is starting off with a positive reputation.
I've always considered Napa to make the best parts of any common local auto part dealer. that said, i'd probably just opt for the cheapest one that i could find with the best warranty available. if this thing breaks or doesn't work it's not the end of the world.
i see advance offers them with a limited lifetime replacement for around $25.
Old 09-29-2010, 07:09 PM
Thanks guys. I'll probably go with a NAPA one. I have never done a heater core on one of these yet, but I looked into it briefly and it sounds pretty quick and easy. What a relief, I was dreading the possibility of having to pull the whole dash and all that. These were the last of the Ford vehicles that were mechanic friendly. After the mid 1990's, Fords usually suck to work on!
Old 09-29-2010, 07:20 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
I repaired mine... hooked it up to the air compressor and put it in a bucket of water, found it
was leaking at the solder joint where one of the tubes was attached to the tank. Cleaned
everything up and re-soldered both tubes, am now hoping for the best as it seems to be
working fine.
If it wasn't repairable, I'd have gotten a Ford OEM variant from Parts Guy Ed or Green
Sales Co:
Ed: www.partsguyed.com
Green Sales Co: Green Sales Company - Obsolete Ford parts, Lincoln, Mercury parts Green Sales Company, supplier of obsolete Ford parts and Lincoln / Mercury parts.* Our Ford parts inventory represents all Ford and Lincoln / Mercury products from 1950 to the present.
Old 09-29-2010, 07:55 PM
ctubutis's Avatar
How I hooked to air compressor:
Connected a short piece of heater hose to one tube with a hose clamp. For the open end of
hose, used another hose clamp to clamp around a large bolt or wooden dowel or whatever I
could find that would seal the end.
Attached another short piece of hose to the other brass tube using another hose clamp.
To pressurize, I stuck the end of nozzle similar to this:
into the open end of the hose, sealed with duct tape. Pressure doesn't need to be real high
(I wouldn't go above 50 or so PSI) and it doesn't really matter if it leaks, any leaks in the
core will still show up when it's submerged in water.
A bicycle tire pump could do the same thing.
Old 09-29-2010, 08:47 PM
Interesting idea. I have done a similar method with the air nozzle to blow out clogged cores on cars. I think I'll be better off just replacing it with a new unit. It may not be worth the time to me to find the leak and then repair it. But, I will consider this. It depends on how the thing looks when I get to it. If it looks far beyond repair, I'll have a replacement ready to go.
Old 09-29-2010, 08:57 PM
MudRacer89's Avatar
MudRacer89 MudRacer89 is offline
MudRacer89 is starting off with a positive reputation.
ive replaced the one on my 81 f150 an it was easy. mine was, if i remember right four screws on the fire wall an two nut behind the glove box. take the heater box apart and there it is. an a thought on the heater core, id just replace it, they are really cheap. good luck
Old 09-29-2010, 09:24 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
If you try to repair the old one use acid core solder, same for radiators (not for electrical though thats what rosin core is for,)
Old 09-29-2010, 11:27 PM
iwals's Avatar
iwals iwals is offline
iwals is starting off with a positive reputation.
What a coincidence, I'm in the middle of replacing the heater core on my '86. Mine has the heater core in the engine compartment. The engine compartment bolts are easy to get to, although one I did by feel only. The ones in the passenger compartment are a little harder--two are easy and one was really hard to find. It is above and almost behind the plastic ductwork. I had to use a deep socket with a universal adapter and then an extension on that to get it. Another problem I had was one of the bolts in the engine compartment had a nut that was turning with it. I don't know what Ford was thinking there.
I had O'Reilly order me a core. The one they had listed for my truck had longer bent outlets than mine. Mine has the shorter tubes and they called it a high output heater. O'Reilley had it for $22 with a lifetime warranty. I checked with another parts store and they wanted $40 for the same one. Looking at the computer screens of the two stores it looked like they were the same supplier. Aluminum was my only choice. Good luck with yours.
Rick
Old 10-01-2010, 07:13 PM
Rick is your truck equipped with AC? I took mine apart today, it seemed different than what you described. It was surprisingly easy. I still have not ordered the part. Here is what I found:
Old 10-01-2010, 07:15 PM
There was a puddle of coolant in the bottom of the box. I always wondered where my coolant was going! LOL
How do you know if your truck is equipped with a high output heater or a standard heater??
Old 10-01-2010, 09:12 PM
iwals's Avatar
It turns out getting a replacement wasn't as easy as I thought. O'Reillys got me the wrong core. They then looked it up in a catalog, and there was a picture of my heater core. They ordered that, and the next day they still got the wrong one. Four trips to town wasted. I went to Auto Zone across the street and they had what I needed in stock. Turns out it wasn't a high output heater. Also, the guy at AZ listened to me. I asked him to check for the non-AC version, and that was what I needed. O'Reillys ignored me when I told them that. I've heard bad things about AZ, but they also have a lifetime warranty on the core.
My 1986 is apparently unique in several ways. According to my Hayne's book, the type of heater core I have is for non-AC because it's in the engine compartment. But I have AC.
I hope to put everything back together tomorrow. As far as difficulty, finding the hard to reach nut in the passenger compartment wasn't too bad. It was the messed up one in the engine compartment that kept spinning that made this project a pain.
Rick
Old 10-01-2010, 09:21 PM
ctubutis's Avatar
Quote:
Which tells me you likely have dealer-added or aftermarket-installed AC instead
of the factory-installed variant.
Need seal for heater core. 4x4 Bart 1973 - 1979 F-100 & Larger F-Series Trucks 44 03-07-2014 12:39 PM
2000 Expy Heater Core and Blend Door brimis 1997-2006 Expedition & Navigator 1 09-24-2013 01:09 PM
heater core brand that holds up best??? geoaigel 1997 - 2003 F150 65 11-01-2012 10:45 AM
Heater core keeps going out wash31570 1997 - 2003 F150 4 11-30-2010 02:44 AM
Heater core tips by and for a novice jpete9803 Aerostar 11 02-21-2004 10:15 AM
Tags
150, 1986, 86, core, duty, f150, ford, heater, heavy, inlet, location, partes, pump, truck, water, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
