AOD/Flexplate for 76 351 - Ford Truck Enthusiasts Forums
Old 09-29-2010, 12:51 AM
corner27's Avatar
corner27 corner27 is offline
corner27 is starting off with a positive reputation.
Im not sure what section this should be in, but I figured since the engine is a 76, this section should work.
I have a 76 351w, and a AOD trans that I will be bolting to it. From my research, I believe the transmission is from a 83 Thunderbird.
My question is about the flexplate. I have the original 164T 28oz plate, but I was wondering if this will work with the tranny. I'm fairly new to working on engine, so I'm not sure how these all match up. I do know that if the thunderbird had a 302, it will of had a 50 oz plate. Does this make any difference?
Thanks
Corey
Old 09-29-2010, 02:12 AM
droppedf100's Avatar
droppedf100 droppedf100 is offline
droppedf100 is starting off with a positive reputation.
Yes I believe the original 351w flexplate will work
Old 09-29-2010, 06:30 AM
DKW 86's Avatar
DKW 86 DKW 86 is offline
DKW 86 is starting off with a positive reputation.
Quote:
If not, would try the flexplate off the 83 or later Bird. Anything with an AOD and a Windsor SHOULD work.
Old 09-29-2010, 08:57 AM
Blown 331's Avatar
Blown 331 Blown 331 is offline
Blown 331 is gaining momentum as a positive member of FTE.
Actually an 83 T-bird would have a balance of 50oz on the flexplate and the 1976 351w would have 28oz so that will not work.
A C4 and an AOD require the same flexplate so if your 351w originally had a C4 behind it then you can keep that flexplate with your AOD.
Old 09-29-2010, 09:05 AM
seefriedm's Avatar
seefriedm seefriedm is offline
seefriedm is starting off with a positive reputation.
You also need to consider external versus internal balancing of the motor. Hense the differences in 28oz vs 50oz. the motors harmonic balancer is also different. I did this conversion with a 302 in a 73 Mustang and AOD years ago. I did end up getting 30mpg when I was done, had the 2brl, AOD and 3.00 gears and kept my foot out of it. The darn thing was just about 1100 rpm's at 60 mph. On a drive from Sacramento to Burbank I used 1/2 tank of gas.
Old 09-29-2010, 12:22 PM
Quote:
If its a 76 motor he can use the original balancer and flexplate for the motor and the AOD trans should work fine.
Old 09-29-2010, 12:28 PM
Flat_Ford Flat_Ford is offline
Flat_Ford is starting off with a positive reputation.
i second that it will work...only thing you need to do is see if the torque converter will bolt up to the flywheel...if the converter will bolt..slap that bad boy on.
Old 09-29-2010, 06:12 PM
corner27's Avatar
I went outside and it bolts up to the torque converter so looks like it should all be good. The guy gave me a starter from a 460, he said this should work. Opinions on that?
Old 09-30-2010, 12:02 AM
idk...first and worst thing you need to do is give us some more info....how many teeth are on the flywheel? it's a pita...but make marks about every ten teeth and you'll know...then you can narrow it down to what starter you need.
Old 09-30-2010, 12:29 AM
corner27's Avatar
I think I said in my original post that it has 164 teeth and its 28oz. It came bolted to the 351.
Old 09-30-2010, 12:41 AM
sorry man i somehow skipped that....my bad...i'm pretty sure whatever starter for the engine and the automatic it came with will be right for it...what i suggest doing is what i did with my last project...find the numbers on the starter you have...if it's a replacement you can look it up and see what trans it's for....the only reason i could think of it not fitting would be either the bolts for the trans or if the starter is for a manual trans....
my apologies again for not seeing that you had given all the info.
Old 09-30-2010, 12:48 AM
corner27's Avatar
No worries. ill get the numbers and look it up. I'm not sure what trans it came from. He gave it to me because he sold the originl before I got the engine and tranny
Old 09-30-2010, 01:11 AM
that's the best bet for ya....lots and lots of research...then some more research... idk what it'd cost to ship a starter to ya but i got one on the shelf that you could have...i'd just have to see what exactly it's for.
Old 09-30-2010, 06:53 AM
DKW 86's Avatar
Thanks, i misread the date on the 351W...OOPS! Sorry!
Old 09-30-2010, 10:44 AM
Blown 331's Avatar
Quote:
No prob but just so you know the date would not matter. All 351w have 28oz, they did not change to 50oz like the 302 did.
Automatic Transmisson Flexplate for 5.8 4R70W TexasGuy001 1987 - 1996 F150 & Larger F-Series Trucks 21 01-18-2016 12:25 AM
351W 28oz balancer and flywheel questions eBronc3 1966 - 1977 Early Broncos 2 11-05-2015 06:38 PM
302 and AOD - vibration?!? TireDood 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 03-25-2015 11:03 AM
AOD to C4 Transmission Change GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 27 04-25-2011 01:53 PM
302 Block Plate and Starter Question GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 04-20-2011 05:29 PM
Tags
1979, 351, 460, 73, 76, aod, f100, flex, flexplate, flexplates, ford, modified, plate, starter, teeth, truck, winsdor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
