codes p0316,p0300,p0302,p0303 - Ford Truck Enthusiasts Forums
Old 09-28-2010, 06:56 PM
soto8704 soto8704 is offline
soto8704 is starting off with a positive reputation.
hey guys, I have a truck f150 v6 2004. it's giving me the codes p0316,p0300,p0302,p0303.
I check for spark on plug #1 did no have it, so I replace the ignition coil. With no luck. also replaced the plug wires, same result. What could cause missfire on cyl.#2 and cyl #3. Any ideas?
Old 09-28-2010, 07:07 PM
Coskid's Avatar
Coskid Coskid is offline
Coskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to behold
Well how many miles are on the truck and when was the last time (if ever) were the plugs replaced?
Also do you have the 4.6 or 4.2 V6?
Old 09-28-2010, 07:09 PM
Greg B Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
P0300 is a random multible misfire detected. P0316 is misfire detected on startup (1st 1000 revs.) I would recommend getting or borrowing a powertrain and Emission Control shop manual and follow the diagnostic routine for the codes mentioned. As to what could cause the codes or misfires, there are a number of things that could be the cause. It possibly could be a bad coil, plug, boot, fuel injector, or even fuel pump. It could also be a problem with the wiring harness for those coils. The easiest and quickest way to diagnose the problem is to follow the routine in the shop manual. Fixing the problem should be easy. Finding it will take a little more effort.
Old 09-28-2010, 07:43 PM
4.2 engine. I replaced the ignition pack. I will replace spark plugs tomorrow. what 's bother me is that two cyl. missfired. do you now the firing order?
Thkx.
Old 09-28-2010, 08:13 PM
I do not know the firing order. That info is in the shop manuals.
Old 09-28-2010, 10:21 PM
jstnromero's Avatar
jstnromero jstnromero is offline
jstnromero is a splendid one to beholdjstnromero is a splendid one to beholdjstnromero is a splendid one to beholdjstnromero is a splendid one to beholdjstnromero is a splendid one to beholdjstnromero is a splendid one to behold
the firing order for the 4.2L is
1-4-2-5-3-6
2006 F-150 5.4 P0053 Stevenmed 2004 - 2008 F150 4 03-11-2016 10:28 AM
Codes P0113, P0316, P0302 STXsilver 1997 - 2003 F150 1 10-25-2015 12:55 AM
Misfire w/Lean daveplot 1997-2006 Expedition & Navigator 3 07-09-2011 10:00 AM
It runs awful when it rains 88 Bronco Ranger & B-Series 21 12-22-2009 11:46 AM
Fuel problems Steveaustin 2004 - 2008 F150 9 05-24-2009 10:07 AM
Tags
03, 0316, 350, 42, 46l, 64, code, diagnosing, escape, f150, ford, p0300, p0302, p0303, p0316, po300, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
