Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Minnesota Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Minnesota Chapter Join Chapter, Leader: fordpower88
  #1 (permalink)
Old 09-28-2010, 06:35 PM
abes250 abes250 is offline
Garage is empty, add now
abes250 is starting off with a positive reputation.
Question best exhaust
Hey folks, I have a 99 F250 excab, with the 5.4l. I am in the market for an after market exhaust system. I was looking into a good cat back setup, but not sure on a few things. Im looking for a single out, and would like it to sound pretty good. Im leaning towards Flowmaster but not sure on which series yet. My cat is plugged so I was thinking about not even running one, anyones thoughts.
  #2 (permalink)
Old 09-28-2010, 08:08 PM
DieselCamper01's Avatar
DieselCamper01 DieselCamper01 is offline
2001 Ford F-350
DieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to beholdDieselCamper01 is a splendid one to behold
I am no expert on aftermarket exhaust on a gas engine so I cannot help much here. I know there is a company right here in MN called Heartthrob I believe. I would check them out as an option. Where are you located?
__________________
Jay
2001 F350 Lariat CC LB 4X4, Various mods
http://www.roadsidehelpnetwork.org/
  #3 (permalink)
Old 09-28-2010, 08:29 PM
fordpower88's Avatar
fordpower88 fordpower88 is offline
MN Chapter Ldr
fordpower88 has a great reputation on FTE.fordpower88 has a great reputation on FTE.fordpower88 has a great reputation on FTE.fordpower88 has a great reputation on FTE.fordpower88 has a great reputation on FTE.fordpower88 has a great reputation on FTE.
I am no expert either on this but I guess the question is how loud do you want it? That may determine wether or not you want a cat on or not. The place Jay mentioned is located in Litchfield but you can get there systems alot of places on the net. They can install at there factory also if you want. Here is there website Heartthrob Exhaust. I am not sure how there prices stack up against Flowmaster though. I had there exhaust on my '67 Camaro and it sounded great and there quality was great also!
__________________
Troy
'01 F250 CC SB 7.3 PSD, 160,000 miles, PHP tunes, BTS Trans, 6.0 trans cooler, 6637 w/Petes cover, DiPricol gauges, WW-II, HPX, IH bellowed up-pipes, MKO 5" exh.
'04 Ford Explorer XLT, 4.0, 63,000 miles
  #4 (permalink)
Old 09-28-2010, 08:50 PM
bsiebert's Avatar
bsiebert bsiebert is offline
1974 Ford F-100
bsiebert is starting off with a positive reputation.
I would suggest you keep that cat in there. Without one, or plugged like it is (which I have a hard time believing) will throw O2 codes and keep your check engine light on. What I would do in your situation is run duals with a Magnaflow X-Pipe Muffler in the middle. I would also get that cat replaced.
  #5 (permalink)
Old 09-28-2010, 08:51 PM
Thanks fellas. Im up here in Duluth. I will check them out! I am always one to keep it local.
  #6 (permalink)
Old 09-28-2010, 08:56 PM
bsiebert's Avatar
1974 Ford F-100
I'm in Duluth also.... go down to Big Daddy's down in West Duluth. They'll do a good job and are decently priced. Up in Hermantown at the new place that took over the old Radco building (across from Gander Mtn., I forget the new name) they were advertising 200.00 dual exhaust about a month ago. I would check with them also.
  #7 (permalink)
Hey thanks. Ya, I was aware of the O2 codes and light but, just in the planning stages now. I will check it out. I was thinking of a 2 1/4 in and 3" out. If duals, should I keep the stock pipe size? Im looking for a good sound, not super loud, but a cool deep sound, but my main concern I guess is it see's a fair share of towing, so would like to kinda get the total package.
  #8 (permalink)
Old 09-28-2010, 08:58 PM
Sweet! We'll do! Thanks man!
  #9 (permalink)
Old 09-30-2010, 09:37 AM
HP junkie's Avatar
HP junkie HP junkie is offline
2004 Ford F-250
HP junkie has a very good reputation on FTE.HP junkie has a very good reputation on FTE.HP junkie has a very good reputation on FTE.
You can eliminate the cats and get a sensor that plugs into the O2 spot to trick the comp. into thinking they are there and ok. Just a thought if you want to go that route.
__________________
Cory
'04 F250 6.0 SRW CC LB 6-speed 210K, Edge juice w/attitude, open exhaust, blue spring.......
'05 Freestyle Limited 3.0 CVT 109K
  #10 (permalink)
Old 10-02-2010, 10:56 PM
1965f100factory4x4's Avatar
1965f100factory4x4 1965f100factory4x4 is offline
1965f100factory4x4 is starting off with a positive reputation.
if your looking for loud just run right off the manifolds right out BEHIND the front tire, haha.
__________________
Minnesota... home of 10,000 lakes, 18,635 swamps, and 7 fish
MN chapter member
Tags
2010, 4, big, daddy, duluth, ecoboost, exhaust, f150, f250, f350, ford, heartthrob, mn, places, towing, trucks, west
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
