F250 4x4 Hub Vacuum Leak - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-28-2010, 12:20 PM
daculpepp daculpepp is offline
daculpepp is starting off with a positive reputation.
I've been troubleshooting my ESOF vacuum-operated hub engagement. I get the proper vacuum levels at the hubs with the vacuum hoses plugged at the hub, but with either hub connected to its vacuum line the vacuum is low. I think that indicates a vacuum leak in both hubs.
I have been unable to find any good troubleshooting techniques for finding hub leaks. The o-ring on the hub-lock mechanism appears to be ok. I don't know what provides the seal around the axle. Anyone who can help?
Old 09-28-2010, 12:30 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Use a vacuum pump with a gauge, hook it to the nipple on the knuckle, and pump it up. If it holds vacuum, it's good, if not, well... you get the idea
On the auto hubs, there is a white long rectangular "filter" in the middle of the ****. Cover it with your hand while checking if the hub holds vacuum. If that filter is leaking the vacuum, chances are the diaphragm in the locking hub is ruptured. If it still doesn't hold vacuum, it's most likely the knuckle seal.
Old 09-28-2010, 12:32 PM
dchamberlain's Avatar
dchamberlain dchamberlain is online now
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
The only diagnostic I am aware of for testing the actual hub seals is to use a hand vacuum pump attached to the hub itself to see if it will pump down and hold a vacuum. If it won't, one or more of the hub seals are bad.
Guzzle's 4x4 Needle Bearing Lube page is also a good reference on what it takes to tear down the hub to get to the rear vacuum seals.
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Edit: And what he said ^^^^^^ (while I was typing)
Old 09-28-2010, 12:49 PM
Krewat's Avatar
David, we usually step all over each other on the ESOF topics, don't we?
Old 09-28-2010, 12:57 PM
I suppose the odd part is that the only ESOF problem I've ever actually dealt with in person was a bad shift motor relay. I just read a lot and use the service manuals and put it together.
I'd rather see a dozen helpful but redundant responses to someone than one post leading them in the wrong direction.
Old 09-28-2010, 01:07 PM
Krewat's Avatar
I had one problem with it myself, and it had to do with the latching mechanism failing. But having read the entire diagnostic procedure, and gone through it all with a pump and gauge, I'm the same way as you. Willing to help out because I understand the system.
Haven't had ANY problems with the transfer case in 8 years, just the hubs at 1.5 years after purchase, and decided to put on Warns. And use Termalene grease on the needle bearings (one was rusty when the hub itself went south). No problems since.
Old 09-28-2010, 02:53 PM
Thanks
Thanks, everyone, for your input. Very helpful. I'm glad I found this Forum.
Old 12-28-2013, 09:57 PM
flinty72's Avatar
flinty72 flinty72 is offline
flinty72 is starting off with a positive reputation.
I have been having trouble with mine lately I can her it wanting to go in but won't any ideas on what this could I did think it was a vacuum leak
Everything You Wanted To Know About The IWE System...And Then Some xjcamaro89 2004 - 2008 F150 404 01-03-2017 12:59 PM
ESOF not working/hub seal Van Diemen 1999 to 2016 Super Duty 0 05-03-2015 11:35 PM
Vacuum Pump (4WD and AC) mmenzies 6.0L Power Stroke Diesel 22 11-07-2012 12:02 AM
Vacuum Diagram JaySVX Excursion - King of SUVs 0 12-28-2008 12:38 PM
ESOF vacuum pump problem. conger 1999 to 2016 Super Duty 16 10-20-2008 06:58 PM
Tags
2003, 2004, 2008, 4x4, f250, ford, hub, hubs, leak, leaks, line, seals, vaccume, vaccuum, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
