Please help! No oil, added 5qts., and still not a drop on the dip-stick!
100% correct. I failed to inspect the tube close enough, it is rotted by the manifold and the stick was not going in all the way. So I went to the dealer and bought the part, it was $20. The oil is now at the correct level after removing the 6 extra qts. I just went ahead and changed all the oil and filter. Thanks for everyone's help!!
This is the only explanation that makes sense--I was gonna accuse you of leading us on with a line of BS...hope you're recycling the old oil...I'd probably save it for my lawnmower or give it to a friend with a junk car.
Good luck,
George
Good deal...you really had me confused too, wondering if you had an oil-drinking tapeworm living inside your motor or something
Good luck,
George
Good luck,
George
What is most remarkable is that the engine was not damaged
If anyone had any doubts as to the durability of the 4.2....you can put your mind at ease
I'm glad you got your truck sorted out; you really had me scratching my head.
George
I wasn't thinking about *your* kind of lawnmower. The one I've got, I found down the block by the curb on trash day--looks like one of the neighbors decided to get a lawn service. I cleaned out the gas tank, sharpened the blade, and it's been great for 2 years. Actually, I have some nice Valvoline Synpower in it because I had half a quart in the garage...didn't even change the spark plug yet.
George
George
I have the same problem. .
I changed the oil, added 6 quarts, and no sign of oil in the dipstick. The oil gauge shows normal pressure and the warning light goes off when I start the engine. I bought a dipstick for the same engine (4.6L) in a junkyard, and still the same problem. There's no sign of oil leak or burning.
Problem solved!
No Oil
Hello everyone! About a month ago I bought a 2000 f-150, 4.2l v6, 185,000miles, automatic, reg. cab, short box. When I was looking it over I checked the oil, it was a little low but black and surely used, so I assumed it didn't have a leak or use too much. The day after I got it I changed the oil using gastrol 5w-30 and a fram oil filter, the oil level was fine, I checked it again the day after and it was also fine. Today, after being driven 1,000 miles I decided to check it, and there was not a drop on the stick!! So I added 5qts. checked it and still nothing, added 1qt. drove around the block, and when I got home there's still not a single drop of oil on the dip stick, how can it be completely blank after adding 6qts.?! I park it in the same spot everynight, and theres no oil where I park. Theres no visible leak around the filter or drain plug. The anti-freeze and transmission levels were both fine and continue to be. The dip stick tube is into the engine block as far as it should be, and the dipstick goes down good, so I dont think the measuring method is mis-construed. Any help would be greatly appreciated!!!
grizzlyheart
21
04-09-2017 12:21 AM
ironhead86
05-17-2011 01:48 AM
