79 f150 4wd brake rotor removal warn hub
I'm hoping someone can help.
I'm replacing the front brake rotors. I have Warn manual hubs. So far I have
removed wheel, caliper, and hub control.
Now that I can see inside, there is a snap ring and have removed. Can someone tell me how to proceed from here. I am a greenhorn, so let me get that out of the way. Step by step would help, and I can take pictures if that helps. Please!
This thread is where I got the information to replace the bearings in my front rotors... this is at least part of what you are trying to do
see the reply from Kirbys73F100
https://www.ford-trucks.com/forums/8...-question.html
Thanks!
Thanks 'Nice' and 'Physics'. That helped alot. I had removed the snap ring off the axle, but did not see the ring hiding at the edge of the hub. I ended up going down to Schucks to get the spindle nut remover. Got hung up on the "washer" between the 2 lock nuts, finally figured out it comes straight off, kept trying to turn it. Got the bearings repacked, new rotors are on, then ran out of time. All I've got left is the new calipers and pads, bleed the brakes, and I'm home free. (Did I just hex myself?) I'm quite excited, there is nothing like working thru a problem. I would not hesitate to do it again now that I know whats in there. Bummer that between 3 manuals, none of them want to talk about how to do it. Thanks again!
consol
1999 to 2016 Super Duty
23
12-05-2023 12:13 PM
joshofalltrades
03-05-2013 01:39 AM
gd98tj
Escape & Escape Hybrid
07-16-2004 11:24 AM
