My 1966 Ford F250 Custom Cab
It has been molested, painted with a paint brush and generally abused. But I picked it up as a running and driving vehicle for $900. It has an automatic transmission and a 352 2 barrel motor. Supposedly it is a camper special, but not sure how you would tell that. It has all the original chrome, but it is not in very good shape. It has been painted over
So far I have switched the wheels over to 2004 Chevrolet chrome 8 lugs (took some work to get them to fit the rear hubs, but for $40 for the set with tires it was worth the work), a pertronix ignitor with an Accel performance coil. It seems to run quite a bit better with the new ignition set up!
Now it is time for the restoration....and the stripping of the paint. I have done it once before, but it has been about 16 years since I last did body work. But here is a picture of the truck from the day I bought it:
Well, tonight Bertha hauled home her new engine and transmission. It is a 1978 460 and C6 transmission I managed to pick up for $250. Both will more than likely need rebuilding, but that is not an expensive option. The 460 had all the brackets and accessories from AC to PS to smog pump! I thought it was quite the find.
Well after looking into forged piston and rod costs I decided to just spend the bit extra and go with a 535 CI stroker kit made by Probe Racing. Think we are going to end up fuel injecting it and trying to scavenge as many parts as possible from a fuel injected 460 for now with some slightly larger injectors.
Well, I was told it was a Camper Special, but have absolutely no documentation to back it up. As far as I can tell, there really is no good way to tell. I "hear" that the only way to tell was a trailer wiring harness or some other option under the dash, but it honestly does not concern me enough to try to get it documented. I do not have an original window sticker or anything like that.
