Thanks for the welcome. I'm just learning how to navigate this site and how things work here. by the way, I have a 1967 F250 Camper Special, Ranger. The 352 was swapped for a 390 2bbl with C6 tranny. Plan to do lots of upgrades and make this a nice comfortable ride. Current project is upgrading to power brakes and then in the spring it will be disc brakes. I will also see if I can swap out the worn out bench seat for something out of a late model truck. I'll try to post pics when I figure that part out.
Wade
Welcome to the chapter the seat is easy I put a seat from an 89 in the 67 f100 I had had to unbolt seats from slide bracket drill out the threads on seat brackets so the bolts from the slide brackets fit though and put the nuts back on and you can use a seat up to 96 without building new brackets.
Thanks for that bit of info, my wife is debating whether to go with bench or buckets. We had a Ford Explorer once that had very comfortable bucket seats.
Welcome to the chapter! I have buckets in all my 65s. Put Beamer buckets in the last one, very comfy. 6 way power with lumbar. Plenty of options to start things happening in other places.
Welcome to the Chapter Wade, you'll like it, as you can see there's lots of help available.
thanks, I'll need a bit of help as I'm learning about this old truck. I'm wanting to fix it up to look factory new again. It will be used for dump runs, going to the hardware store etc... but who knows now that we have 3 car shows here in Cottage Grove I might enter the old truck in a modified class if I can get it show worthy.
