Decode Engine Tag ID
I pulled these numbers off the metal tags attached to my 1964 F600 and 1966 F350 engines. I could use your help decoding them. I know what the first two numbers are in each top row but can someone else school me on the rest of the numbers? Thanks.
1964 F600:
330 64 2
4 C 605 A
1966 F350:
352 66 6
6 D 295 S
<!-- / message --><!-- edit note -->
1964 F600:
330 64 2
4 C 605 A
1966 F350:
352 66 6
6 D 295 S
Heres the skinny on the tags:
The 330 is as follows: 330= cubic inch displacement
64 = the model year
2= the revision level
2nd row: 4= production year(1964)
C= month assembled(March)
605 A= Engine code number, doesnt affect engine ID
The one thing I did get from the Parts catalog where the tag info is that
its set up to run a Holley 2 bbl carb.
The 352 in the 66: 352= cubic inch displacement
66= model year
6= revision level
2nd row: 6= production year(1966)
D= month assembled(April)
295S= Engine code number, doesnt affect engine ID
Engine is set up to run a Ford 2 bbl carb
This info is all from the Master Parts Catalog, section 60pg 14 (330 engine)
pg 13 (352 engine)
Hope this helps, cs65
64 = the model year
66= model year
6= revision level
pg 13 (352 engine)
Thank you. I was thinking about picking up the HiPo Master catalog but in the description it didn't list the F600. Do you happen to know if it's in the catalog (on the CD)?
Here's the description from the HiPo Website...
"These discs include the part numbers and illustrations for all 1964-1972 Ford F100, F150, F200, F250, F300, F350, F500, E100, E150, E200, E250, E350, B500, B600, N500, N600, WT, L, LN, LNT, LT, 800, 900, 1000, 1100 diesel Trucks, Econoline Vans, Falcon Station Bus, Falcon Deluxe Club Wagon, and many more."
Thanks again!
Thanks again!
64 = the model year
66= model year
6= revision level
pg 13 (352 engine)
64 = the model year
66= model year
6= revision level
pg 13 (352 engine)
Erich.Vongeist
06-24-2009 01:44 PM
