Go Back   Ford Truck Enthusiasts Forums > Marketplace > Want to Buy > WTB - Parts & other
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
  #1 (permalink)
Old 09-26-2010, 09:15 PM
eallanboggs eallanboggs is offline
Garage is empty, add now
eallanboggs is starting off with a positive reputation.
brake proportioning valve 86 F150
I need a proportioning valve for my 86 F150. I don't want to dig through a bone yard for a 25 year old brake part that is probably in as bad a shape as mine. I'd like a new one or at least rebuilt if somone knows a supplier. Tried auto parts stores and eBay motors with not luck.
  #2 (permalink)
Old 09-26-2010, 11:13 PM
lobo1117's Avatar
lobo1117 lobo1117 is offline
lobo1117 is starting off with a positive reputation.
Try Jeff's Bronco Graveyard....
http://broncograveyard.com/bronco/i-...pro-valve.html
__________________
NOS crate 5.8 Lightning shortblock * GT40 intake w/ 1" Spacer *
Y303 Alum heads * 1.6 RR * E303 cam * Kirban AFR *
FRPP Mass air * 30# inj * T58 headers * Magnaflow Dual exhaust *
CAI K&N cone * 170amp alt * Griffin alum rad w/ Efan *
B&M TransPak/Diablo mod valve * Hughes Tranny Pan *
Eaton Posi w/ LPW Girdle * Electric Ed's Cables *
  #3 (permalink)
Old 09-27-2010, 11:12 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
(sigh) You tried autoparts stores, looked on ebay...found nothing, but you didn't try the obvious.
E4TZ2B257F .. Brake Differential Proportioning Valve / Available from Ford.
Fits: 1984/89 F150 2WD/4WD / 1984/86 Bronco / Misc. 1984/89 Econolines & F250/350 2WD/4WD's.
MSRP: $366.63 // FTE Ford Dealer Parts Dept sponsor PARTSGUYED.COM price: $263.98.
Since this is a FoMoCo Dealer part only, you won't find it at autoparts stores.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #4 (permalink)
Old 09-27-2010, 03:51 PM
I was saving the dealer as a last resort because of the sticker shock. I did find it at LMC, but they want $300.00 too. Ouch! I took the proportioning valve off, removed the piston and spring then cleaned it inside and out with Q tips and old tooth brushes. I blasted it with compressed air and ran brake fluid through all the ports until it ran clear. It was full of crap being 25 years old. I reinstalled it and added clean brake fluid and then bled the system. The brakes are now working good. I was really trying to avoid buying from the dealer because of the cost because the owner has just replaced the front rotors, pads, calipers, master cylinder and RR wheel cylinder. I didn't think she could afford an additional $300.00 for a proportioning valve after all the other parts she paid for recently.
Tags
150, 198489, 1986, 78, 89, brake, bronco, differential, f250, ford, graveyard, info, jeffs, mod, pressure, proportioning, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
