coolant filter
I won't assume that the OP was using the Dieselsite coolant filter system http://www.dieselsite.com/index.asp?...ROD&ProdID=799 on their old 6.0 or looking to use it on their 6.4 but I wasn't aware of anyone else that had a kit put together. I wouldn't say that no one else is selling a kit though...
I also don't understand the comment that they don't need it. If the OP found it useful in their 6.0 then they're likely anticipating a similar benefit in their new 6.4. Is there anything markedly different between the two motors that would negate the benefits in the newer motor? Not sure that there is, and I'm fairly certain there's been more than one water pump failure on a 6.4. Would this system have prevented those failure(s)? Conjecture...but also a relatively cheap form of insurance @ $119.
This thread caught my attention because in the process of planning the build for the brand new/leftover '10 F250 CC/SB 6.4 I'm picking up later this week. Dieselsite's coolant and tranny filtration systems are on the list along with an OilGuard remote oil bypass filtration system. This one is hopefully a keeper. Based on the feedback I was getting from Blackstone Lab when I had my 6.0, I'm fairly confident in my decision to do so, regardless if no one else is. I should frame my oil analysis report that says the my 6.0 was one of the best wearing ones they had ever seen...
YMMV of course.
I will say that I think any preventative measure is gonna help, I made my own for my 6.0 but I copied the dieselsite system, I only saved about 25 bucks so I will purchase their system this time...and I think I will make my own decision on what I'm gonna put on my truck, the only one who would sway me otherwise would be a tech on these forums... I never had any problems with my 6.0 , I knew how to take care of it and the 6.4 seems to be a very similar motor, I have been around here for a long time and don't post a lot unless I see fit to, but I have a pretty good clue about what to do..... I'm just sayin....
My 6.0 was built to a stout and performing tow monster, and the mission was soundly accomplished. The personal experienced that I gained with that motor makes starting over again with a brand new 6.4 all the more easy and less intimidating, especially considering that the 6.0 was my first diesel.
Good luck with your ride!
on
I am running one on my 2008 6.4 and I also ran one on my 6.0. I think they are needed due to the silicate drop out of the gold coolant. There was a thread with pictures on another forum about a guy who was changing his water pump and you should have seen how chewed up the front cover was. I know on the 6.0 guys were running the coolant filter to help prolong the life of the oil and egr cooler from what they thought was casting sand but some now think it is silicate drop out from the gold coolant. I think I am going to a extended life coolant like that from Cat or International that is made for a diesel engine. The new 6.7 Ford Diesel has a red colored coolant and the ELC coolant is red colored. I wonder why Ford changed coolant if the "premium Gold" was so good? I would run a coolant filter if it was my truck.
Did you buy the truck new? What's your mileage at now? Thanks!
Maybe I'm just lucky
For what its worth International retrofitted coolant filters on all their VT365s(6.0s) built prior to January 2006, at that point they say they corrected the problem which was some kind of coolant reaction with the block heater.
None of their V8s built after that date have or according to them need coolant filters.
