302 spark plugs - Page 2 - Ford Truck Enthusiasts Forums
302 spark plugs
Old 09-29-2010, 06:34 PM
ymeski56's Avatar
ymeski56 ymeski56 is offline
Der Postmeister
ymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputation
Old 10-06-2010, 07:53 PM
Fifty150's Avatar
Fifty150 Fifty150 is offline
Fifty150 is starting off with a positive reputation.
When in doubt, the best replacement is typically OEM. That means Motorcraft. In the case of the 302, there are a lot of aftermarket parts. I'm currently running Motorcraft in my 302. But I'm one of those kinds of guys that will put in something else, if I can save a buck. I just bought some E3 spark plugs for my 256 (4.2L V6). Has anyone tried those?
Old 10-06-2010, 10:14 PM
CLR f-150's Avatar
CLR f-150 CLR f-150 is offline
CLR f-150 is starting off with a positive reputation.
put in what the book says dont go by anything else, Fords use motorcraft or autolite plugs. The e3 plugs say they shoot the spark directly into the mixture, uh dont all spark plugs do that. Dont waste your money, they dont improve anything. Just like the bosch plugs are junk in anything except foreign cars. Well this is my 2 cents anyways.
Old 10-07-2010, 11:31 AM
ymeski56's Avatar
Der Postmeister
Duplicate...
Old 10-07-2010, 11:34 AM
ymeski56's Avatar
Der Postmeister
Uh, No they don't all do that! W/ the E3's, I've never used em (probably never will) but have heard pleasant thing's about em. They do project better than a standard designed, stock gap plug & they are Copper cores! I'd say if your running a stock gap (they're pre gapped & must stay that way) give em a shot & tell us what you think.
Spark Kernel size/ exposure is what you want (I want anyway). You get it by increasing your stock gap size (requires an ignition system upgrade). I also mod the outer electrode (side gap).
Performance Unlimited 4-Wheel & Off Road Center - Hartford, Wisconsin - USA Technical Documents
But after the upgrade, just increasing your gap size alone (w/o sidegap) by 20-25% goes a long way.
http://fullsizebronco.com/forum/show...ht=timing+bump
Old 10-07-2010, 06:38 PM
skyfox10's Avatar
skyfox10 skyfox10 is offline
skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.
I think the gap increase will do more good than the E3 will. Plus the gap increase is free.
Old 10-08-2010, 12:12 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
The E3 is snake oil and its made in China. I would not go anywhere near them. All the plugs like this and Splitfire, Bosch +4 etc are all a joke.
Old 10-08-2010, 11:53 AM
ymeski56's Avatar
Der Postmeister
Quote:
I wouldn't run Bosch "Anything" in our trucks. Gap stretching Copper Cores have been around for years. As long as your ignition system is up for it.
Old 04-21-2011, 05:18 PM
Lumpy87's Avatar
Lumpy87 Lumpy87 is offline
Lumpy87 is starting off with a positive reputation.
Why I will never go near Bosch again.
Old 05-08-2011, 02:09 PM
ymeski56's Avatar
Der Postmeister
Quote:
...so much for 'self cleaning"!
Old 05-08-2011, 02:59 PM
Ton van der Sluijs Ton van der Sluijs is offline
Ton van der Sluijs is starting off with a positive reputation.
Goodevening everybody
Yesterday I obtained Autolite sparkies for my truck; I think the Accel ones are misfiring. Next week I gonna change them. The truck rides nice, but while on the accelerator there are some misfires.
keep you posted
best regards Ton
persistent misfire in #5 cylinder luckybarber 1997 - 2003 F150 7 07-29-2014 02:53 PM
215 balancer damper pulley pholmes350 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 07-28-2014 10:28 PM
floor mats C. Lee Colbert Ranger & B-Series 5 08-10-2013 09:17 AM
1980 ford f100 5.0 not starting. 97 ford jacked up 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 08-09-2013 01:32 AM
gas tank help Twanstyle 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-07-2013 12:51 PM
Tags
1989, 302, 460, 65, cr43ts, cross, engine, firing, ford, gap, mustang, original, plug, plugs, spark, sparkplugs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
