S. California Chapter Join Chapter, Leader:
I need a FI fuel line larger than 3/8
Old 09-24-2010, 02:57 PM
timbuctooCal's Avatar
timbuctooCal
timbuctooCal is offline
(note : my use of the letters "FL" below ,means" a std rubber fuel injection 180 psi .3/8" fuel hose or line )
I have a 76 Seville that has an electric fuel pump(factory).
This fuel pump has 3 separate hoses to get er all hooked up and running.
2 hoses are 9 " in length
1 hose is 15" length
All 3 of the replaced FL are 3/8" .
When I replace the FL with 3 new 3/8 FL the two shorter FL fit fine.
The longer FL wouldnt go on no matter what,including pre boiling,spray siliconing,light greasing. I am now trying hand screwing in a threaded bold to stretch the FL even slightly. I dont expect much because of the rubbers tendency to return to its original shape is very strong.
The old 3/8 FL was stretcthed enough,but it had been on the car for several years . I dont plan on letting my new ones stay" bolted "that long so theyll fit.
I have asked several auto parts places and they dont have FL larger than 3/8.
Ive spent alot of google time and found nothing.
Has anyone run into this issue before and if so how was the hose expanded or where was a larger than 3/8 FL found?
My choices for larger sizes are 7/16 or 1/2" FL. I would hope that would work IF they can be found.
Any info,ideas?
Old 09-25-2010, 07:40 PM
timbuctooCal
Does anyone know if there are 7/16 or 1/2 inch FI fuel lines ?
Even a 3/8 at a lower pressure should be more flexible.
Old 09-25-2010, 09:04 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Call Orme Brothers in Northridge on Monday.
If it's a pressure hose, they will know.
They ship.
High Performance Hoses | Aluminum Fittings | Aluminum Adaptors | Custom Components | Orme Brothers Inc. Northridge, CA - Orme Brothers Live Site or
877-ORMEBRS
Pop
BassFantasizer
05-24-2013 03:02 PM
lawson907
1997 - 2003 F150
08-09-2011 04:57 PM
timbuctooCal
Modular V10 (6.8l)
09-25-2010 11:44 PM
rootbeer
1983 - 2012 Ranger & B-Series
02-17-2010 07:22 PM
TC-Countryboy
Oil & Lubrication
07-08-2009 05:59 PM
Quick Reply: I need a FI fuel line larger than 3/8
