89 Grill Removal
Open the hood, there is a piece of trim that spans the gap from the radiator support and the grill held on with some of those plastic fasteners. Pull that off, you will need some new fasteners. You can get those at Carquest for sure, other parts stores should be able to as well. Once that trim piece is off, look down between the radiator and grill, you will see how the grill is held on. Just squeeze those little tabs at each corner together and start working it out.
Chris
Chris
Cedarghost
01-30-2016 09:31 PM
supertuff
04-14-2014 04:37 PM
