Foil delete. NOW HELP NEEDED! IC BOOT AND CLAMP PROBLEM
When doing a foil delete do you just use a razor blade to cut the foil and insulation off?
What do you use to get the excess sticky stuff off?
Is this all there is to it?
Yes for the most part. Dont forget to wear leather gloves the foil is very sharp. I got as much of the insulation off by hand them I use a cheap painbrush to use a potent all purpose adhesive stripper to get the rest of it off. The adhesive that they used to glue the insulation on is something else. I made up a half round scraper out of a piece of sheetmetal to help the process go a bit quicker.
This is what I used. It used to be called "Solu-Strip", but I guess it was renamed "Handi-Strip". Same stuff and it worked great...
Shop Crown Gallon Handi-Strip Semi-Paste at Lowes.com
I cut the foil just deep enough to pull it from the pipe. Then I used some adhesive remover and a razor blade to get the big stuff off, then some steel wool to clean it up the rest of the way.
I was going to use some Mothers on it to shine it up but that adhesive took awhile to remove
....Tom
....Tom
....Tom
....Tom
http://i1013.photobucket.com/albums/...d/DSCF1522.jpg
Well i Foil Deleted! NOW MY TOP INTERCOOLER BOOT WONT GO ON! I get it on but the clamp keeps wanting to slide in to the center and kick the pipe out when i tighten it down! I even scuffed up the pipe with course sand paper, cleaned the boot with cleaner and the clamp! What the hells going on??
The bottom (closest to turbo) has always been on i only took off the top one. It just wants so slide down tword the other one when i start to clap down real tight but im scared if i dont go tight it will blow off! It was tight when i took it off now 15 minutes later it wont tighten up where it was? the pipe is in all the way and it seats correctly "locked in" or what have you
