Ford Dealer 6.0 Rebuild - Ford Truck Enthusiasts Forums
Old 09-26-2010, 11:42 AM
pbssouthland pbssouthland is offline
pbssouthland is starting off with a positive reputation.
Did some searches on the reliabiliy of the 6.0 after rebuild/mods and found mostly aftermarket advice. Here is the delima I am in; found an 03 F350 crew cab, fx4, automatic, xlt, long bed, with 145000 miles. Price = $12,000. The truck had the usual 6.0 head problems and Ford installed a remanufactured long block and new EGR at 96000 miles. He said that he thought they replaced the EGR and not deleted it. My question is - how do the Ford modifications hold up and would the EGR still need to be deleted. He said he has had no problems since. I think this is probably a good deal but I am a little uncertain. I do not have the resources to build or repair a diesel motor right now, I need something I can drive for a long time.
Any advice would be greatly appreciated. Thanks.
Old 09-26-2010, 12:10 PM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud of
Like so many things, it depends. I'm in the minority that thinks you can have a reliable EGR system unless you are making a lot of HP/TQ. It really depends on how you use the truck.
I doubt that they deleted it as that would be a big no-no with certain Federal agencies regardless if you have local emission requirements for that truck. I don't think that a dealership would run that risk.
Head concerns would depend on a few factors. What caused them etc. There is enough support out there to think that most of the head problems out there could have been avoided if the owners and the diesel techs would have had more knowledge. Now who is to be blamed for that information shortcoming is up for a nice conversation, but I don't think you would want to get into that now. As to that truck in particular, need to find out what caused the issue(s) and how they "fixed" it. Even if you do ARP studs, that in of itself doesn't promise you that you won't be back in there if they didn't do the job right to begin with.
In the end, that truck might last you a lifetime or then again it might not. The usual risks with buying used apply no matter what engine is under the hood. Just try to get as much information as you can on the vehicle and make your decision accordingly.
Old 09-26-2010, 02:11 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
Quote:
Can I apply to join your minority?
Mine is working fine with the EGR --- once I replaced a dud EGR.
Total Rebuild Cost uh60 6.0L Power Stroke Diesel 23 09-06-2014 03:16 PM
EGR Delete or Head gasket problem??? 06f350mrr 6.0L Power Stroke Diesel 6 01-14-2012 11:31 PM
Exhaust suggestions, EGR Delete L. Ward Excursion - King of SUVs 5 12-16-2011 06:51 AM
EGR Delete Kit or Bulletproof EGR cooler mmenzies 6.0L Power Stroke Diesel 96 05-14-2011 02:02 PM
Looking at New Truck Need Your Reassurance! ech0sh4y 6.0L Power Stroke Diesel 15 04-10-2010 11:10 AM
Tags
2005, 60, diesel, ford, motor, not, rebuild, rebuilding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
