Removal of factory radio
Can anyone tell me how to go about removing the factory F250 radio without recking the trim? or please send me a link to a sticky i couldnt find anything.
Am thinking about a double din player to stick in there. also want to see if there is a plug in for the aux button at the back that people were talking about last week
Thanks in advance.
Koboss
Thanks in advance.
Koboss
Yes, your factory 2005 radio has an AUX plug in the back. I've had mine out and it's there. To remove radio: Put steering wheel in full down position.... CAREFULLY, starting at drivers side, pry the moulding trim out with your fingers (Or you can use a narrow bladed screwdriver - don't chip the moulding)....work your way around towards the passenger side. I didn't remove mine completely and just held it out with left hand while I used a 1/4 drive set to remove the 4 bolts holding in the radio....remove the antenna cable and pwr/spk connectors and it'll come out the front.
I believe you should be able to remove the radio without pulling apart the dash. If your radio has the two small holes on each side of the head unit, you purchase the "hair-pin" release tool from an autoparts store (less then $20), insert them into the holes and pull the radio straight out. Simple.
Here is one that I found
FORD F-350 2005 05 AUX INPUT ADAPTER IPHONE/IPOD TOUCH - eBay (item 360286830767 end time Oct-01-10 13:42:27 PDT)
It will still need a cable from the RCA inputs to the iPod.
I just bought this, I will let you know how it works.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
* FORD FRD04 AUX INPUT ADAPTER FOR AUDIO (2004 AND NEWER CARS WITH 16 PIN PORT -AND- AUX BUTTON)
koboss1
6.4L Power Stroke Diesel
02-16-2010 07:38 PM
