bio diesel processor what welder do i need?
Old 09-26-2010, 11:39 AM
ah1988's Avatar
ah1988
ah1988 is offline
i anm gonna weld the steel drums for the proscessor any advice on what welding machine i should get i wanna weld the drums but i also want the welder to be able to weld like a car frame so it needs to able to do diffrent things
Old 09-26-2010, 12:01 PM
binuya's Avatar
binuya
binuya is offline
A mig set up will do all of that and is relatively easy to learn. Get one with the gas shielding capability. You can weld thin material better with a gas shield as opposed to the flux core wire.
Oxy-Acetalene can also do both plus, you can braze with it. Helpful in making leak free joints when attaching plumbing fittings to the processor drum. Not as easy to learn as mig welding though.
Old 09-30-2010, 07:57 PM
cj06's Avatar
cj06
cj06 is offline
i have done a lot of work over the decades with a Lincoln 225 AC unit . not the best but they can be had used for 100-150 bucks .
6011 , 6010 , 6013 , 7014 , rods work well !!
Old 10-02-2010, 04:52 PM
monckywrench's Avatar
monckywrench
monckywrench is offline
If you are welding drums and want to do actual frame work, a MIG over 200 amps (either Lincoln or Miller) would do the job.
Practice for many, many hours before welding anything on which life depends, and visit welding forums like weldingweb, the Hobart forums, and the millerwelds forum.
I like stick welding, but would get a stick machine with DC capability so I could run a much greater variety of rods. The AC225 Lincoln has a brother that does DC too, or get a used Lincoln Idealarc 250/Miller Dialarc 250 (large, heavy, very nice, last forever).
jimbo1969
07-26-2016 10:03 AM
Anthony Polsinelli
03-24-2016 10:49 AM
winginit
07-11-2015 02:30 AM
bigun72
Paint & Bodywork
04-16-2007 09:38 AM
conter4x4
Garage & Workshop
09-25-2005 07:05 AM
Quick Reply: bio diesel processor what welder do i need?
