Power steering fluid leak
Old 09-26-2010, 05:27 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
Hi all. I have the front end of my truck up on stands, no front wheels fitted, and wanted to check the operation of the steering damper.
http://picasaweb.google.com/SSSimonC...62190422621010
With engine off, I turned the steering full right, checked then full left, probably going from full right to full left in about 5 seconds.
When I was checking the steering damper for full left I noticed fluid had overflowed from the power steering reservoir and was dripping down.
Is this normal?
The PS fluid level seemed to be OK after I cleaned up the spill.
I'm thinking that with the power steering pump NOT operating, turning the steering that quickly somehow caused the overflow - and hoping that there isn't a problem in there.
Old 09-26-2010, 06:05 AM
megawatt00's Avatar
megawatt00
megawatt00 is offline
Picasa Web Albums - SingleSpeedSimon - F250 repairs
Is this normal?
You are100% right on here Simon. This is normal for our trucks.
Old 09-26-2010, 07:19 AM
cj45lc's Avatar
cj45lc
cj45lc is offline
I would check the fluid level again after you get back running and turn the wheels a few times. Don't want to get air in the system.
Old 09-26-2010, 08:22 AM
Waynenap's Avatar
Waynenap
Waynenap is offline
You might want to keep an eye on the cap. When I had to steer mine with the engine off, it blew the cap off and wouldn't stay on properly after that. I had to buy a new one.
Old 09-26-2010, 05:11 PM
SSSimon's Avatar
SSSimon
SSSimon is offline
Thanks all. The cap does seem a bit loose now. I didn't notice anything broken under the cap but will have another look just to be sure.
Old 09-26-2010, 06:03 PM
big poppa's Avatar
big poppa
big poppa is offline
Not to highjack but speaking of our PS caps, was just wondering does our caps have a rubber contact gasket underneath when we put them on?? Or is this for venting of sorts. I never had a gasket on there.
Old 09-27-2010, 08:19 AM
cj45lc's Avatar
cj45lc
cj45lc is offline
I've never had a gasket on mine, they are notorious for being a POS. I've heard many Mustang with this type reservoir wrecked or flipped on road courses with the cap blown off.
Old 09-28-2010, 04:17 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
Yeeesh. I can see another 50c mod coming. Tape the PS reservoir cap on with gaffer tape ensuring that the breather hole remains clear.
Old 09-28-2010, 04:37 AM
Visseroth's Avatar
Visseroth
Visseroth is offline
Yea, mine did the same thing and I snapped the lip on the reservoir, though it still seems to sit on there and doesn't come off I make dang sure to never turn the wheel without the engine running or prepare to clean up the mess.
Les Schwab's learned that lesson too when I scared the crap out of him telling him to not turn the wheel without the engine running. When he asked why I pointed behind the driver's side wheel well and the mess he made. I tried to catch him before he made a mess.
Old 09-28-2010, 05:24 PM
FTrucker's Avatar
FTrucker
FTrucker is offline
Anytime I turn the wheel and the truck was off (like doing a brake job) my cap seems to come off, I tried to bend the tabs back but I Guess I need a new cap. Glad to hear this, just happened to me again.
john
Old 09-29-2010, 04:39 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
Checked my cap after the overflow. There is an O-ring seal in there and the tabs holding the cap down are still present. So no harm done other than the mess.
Old 09-29-2010, 04:51 AM
Visseroth's Avatar
Visseroth
The lid doesn't have a gasket or rubber seal, it uses the plastic on the inside of the lid to seal against the inside of the reservoir neck.
portsample
04-09-2020 09:32 AM
pgguru
1999 to 2016 Super Duty
05-30-2014 12:02 AM
ManfredVonRichtofen
27
01-15-2012 10:08 PM
5.4L to Freedom
18
02-13-2011 03:55 PM
sigtauenus
04-02-2010 11:30 AM
Quick Reply: Power steering fluid leak
