Bench bleeding master cylinder
Old 09-25-2010, 09:35 PM
johaner78's Avatar
johaner78
johaner78 is offline
I've installed a new master cylinder on my '78 F250 crew. The instructions say to "bench bleed" the MC before bleeding the brake lines. Is this absolutely necessary to get the brakes to be nice and firm after bleeding them? I'm not wanting to put fluid in the cylinder to "bench bleed" it (either on the bench or on the truck) for fear of loosing brake fluid out of the ports onto my nicely painted engine bay parts lol while trying to connect the brake lines. Any advice guys?
Old 09-25-2010, 10:22 PM
ranger429's Avatar
ranger429
ranger429 is offline
It is a must! I bought 2 12" pieces of line and bent them over to fit back into the cylinder reservoir. I bled mine on the truck. Much easier than trying to do it on a bench in a vise. Just push the pedal slowly to eliminate spray coming back out.
Old 09-25-2010, 10:33 PM
MarcusPBoldt's Avatar
MarcusPBoldt
MarcusPBoldt is offline
One way or another you need to bleed the the MC, the benifit of putting it in a vice is that you can get all of the air out of all the nooks and crannys a lot easier if the MC is completley level.
IMHO it's a whole lot easier to bleed it on the truck, but unless your planning on bleeding the entire system, which is recomended, you really need to bleed the MC one way or another.
Old 09-25-2010, 10:49 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
The reason "they" recommend BENCH bleeding versus installing it in the vehicle and bleeding it is to keep the MC level in a vise while bleeding the air.
But, I think most people say screw that and do what Ranger showed. Works like a charm.
Josh
Old 09-25-2010, 10:51 PM
4x4 Bart's Avatar
4x4 Bart
4x4 Bart is offline
Ranger has the right idea, I just lay a rag over the top to make sure no splash gets out while pumping and bleeding.
Old 09-26-2010, 11:00 AM
steponit's Avatar
steponit
steponit is offline
The tubes you attach from the MC outlets go into a jar with brake fluid in it.
No fluid leaks anywhere.
Old 09-26-2010, 11:46 AM
78longbed's Avatar
78longbed
78longbed is offline
Johaner, It's good that you are thinking ahead, I had some leaks on the fittings for my new extended front brake lines and by the time I found the leaks it ate right through the chassis saver on my frame. I had to do some touch up.
Old 09-27-2010, 08:14 PM
johaner78's Avatar
johaner78
Ok, so i'll bleed the MC......I like Ranger's idea and then cover it with a rag or something. So my concern is that all the fluid (or even one little drop) will come out of the MC when I take the bleeder lines off and try to connect the actual brake lines. I just can't be touching up paint....that will just kill me to see paint get ruined and have to touch up. So will any drop come out of the ports when switching lines?
Old 09-28-2010, 06:55 AM
ranger429's Avatar
ranger429
Yes several drops will come out when you swap lines. Get plenty of towels. Just make sure you don't press the pedal to hard when doing it my way or you will have a brake fluid mess.
Old 01-24-2014, 10:02 PM
shanes66charger's Avatar
shanes66charger
shanes66charger is offline
im sure youll get decent pedal if you bleed it in the truck, however its not messy at all and you will NOT get out ALL of the air in the truck as its not level.
Old 01-24-2014, 11:35 PM
turbohunter's Avatar
turbohunter
turbohunter is offline
I've done it both ways numerous times and they both work.
However I got a little bleeder helper syringe (Classic Performance Products pn# CP0105) just to make sure and suck or push any air out.
If you make yourself a little bleed kit it becomes easy as pie.
Old 01-25-2014, 10:20 AM
NBC-Steve's Avatar
NBC-Steve
NBC-Steve is offline
I used clear tubing to see how much air is still in the MC.
Old 01-25-2014, 10:58 AM
dustyroad's Avatar
dustyroad
dustyroad is offline
Just a thought you could also use DOT 5 brake fluid which is a little more gentler to the paint.
good to doo
10-15-2022 03:19 PM
jonmammenga
19
08-17-2015 05:05 PM
Iowa-Rob
1983 - 2012 Ranger & B-Series
07-27-2015 11:55 PM
aidandj
08-26-2013 03:35 PM
Quick Reply: Bench bleeding master cylinder
