Where would I go to buy new interior parts for my 99 Ranger? I've looked at LMC. In particular I need a console lid and ash tray assembly. Maybe a new seat cover and carpet later.
My truck has a 55/45 or 60/40, I suppose, split bench. Thanks.
As for the lid, you might try E Bay or a junk yard. You will more than likely have to buy the whole console. Depending on the damage to the lid it may be reparable.
Rog
Reason: spelling
Many times a particular component or part is used in several model years. In checking my catalog, I find many common cab parts for 1998 - 2000 Rangers or even a wider range. For instance, the same molded carpet fits 98 - 05 Rangers. That will allow you to broaden your search for the parts you need as you go through salvage yards. Some parts are also used in Explorers as well.
Reason: Typo
