the old ford strikes again!
Well its almost time for plowing and of course the truck is starting to have problems again. The driver side axle is leaking pretty bad to where I don't think I can use 4wd. Kind of a problem for plowing. Is it just hopeful thinking that its just the outside seal or does the outside seal not even do much and am I going to have to pull the whole diff and tubes apart. I hope not. Never taken a carrier apart. What do you guys think?
Hey I'm not positive about this but I believe you will have to change the seals up around the differential. The axle tubes on a front axle should be dry and the outter seal by the end of the tube is mostly to just help prevent dust/debris/mud/water from filling up the axle tube. Its not meant as an oil seal, as far as the axles I've worked on at least. Speaking of this I gotta get around to changing my inner axle seals too!
Thanks for the info guys. Looks like I have quite the project ahead of me. Let's see how many rusted bolts I can break off lol. Is there anything else I should do while its apart? I was thinking of shocks and add a leafs and track bar and spring bushings. Anything else? These trucks are pretty frustrating sometimes
vasten
11-12-2008 09:07 PM
caperail
11-17-2004 09:44 PM
