Ford 1949 F5 Wheel
Old 09-25-2010, 07:29 PM
Gotanoldtruck's Avatar
Gotanoldtruck
Gotanoldtruck is offline
Ford 1949 F5 Wheel
Here is a picture of the wheel from my F5. Can I/should restore these? Do any of you have these wheels on your truck?
Picture is the Gallery as I was not able to upload it.
Old 09-25-2010, 09:44 PM
harleymsn's Avatar
harleymsn
harleymsn is offline
Can't tell for sure from that picture. You need to look at the other side to be sure.
As Truckdog tried to lead you in the right direction in your other post, check out the threads he linked and look at this picture
if your rims look like this, with the wide band inside, Please, please, please, take these warnings serious!
Originally Posted by truckdog62563
While you are getting it sorted out and running, I'd also suggest learning about its wheels. They are probably the widowmaker variety. Here's some old threads about them. BTW, welcome to FTE. Glad to have another big truck getting saved. Stu
https://www.ford-trucks.com/forums/8...dowmakers.html
https://www.ford-trucks.com/forums/8...ow-makers.html
https://www.ford-trucks.com/forums/6...ml#post5470496
Old 09-25-2010, 10:32 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
Marmon-Herrington Man
Here's your pic so others can chime in. There does seem to be a line around the inner rim face that could be the edge of a lock ring, or it could just be a visual trick based on the contour of the rim lip. Looking through the one upper hand hole (the one at about 11:00), though, I might be seeing part of the widowmaker joint. So it's really hard to judge from my laptop screen such subtle details in a picture. Like Joe says, the way to be absolutely sure would be to see the back side. Let the air out before removing the wheel/tire from the truck. Stu
Old 10-26-2010, 02:29 PM
F-6Larry's Avatar
F-6Larry
F-6Larry is offline
If you're a little crazy and try to deal with these split rims (either version) wrap 3 or 4 chains around the wheel/tire combination. Chains whose hooks hook and stay hooked and maybe 5/16" type A chain not unknown quality chain. More than a few have died taking chances. Garages use a steel cage. They probably won't come apart going down the road if you're extremely vigilant putting them together and practice little tricks along the way to insure good, proper seating. Still illegal in NH tho.
Old 10-26-2010, 03:24 PM
truckdog62563
There are plenty of stories of widowmakers coming apart while on the road. Worst case is an outer rear dual that has the side ring blow out away from the truck into whatever/whomever happens to be in its line of fire. If a front wheel or inner dual blows the ring will be contained under the truck, but can cause an accident none-the-less.
The widowmaker wheels never have been outlawed federally. The only action taken by OSHA was to require additional installer training which was pointless. I've heard that some states have outlawed them, though. Is that a fact in NH? Anybody know of other states? Stu
Old 07-27-2012, 12:06 PM
John & Old Ford's Avatar
John & Old Ford
John & Old Ford is offline
Setting the legality a side. Any options to “upgrade” the wheels with something safer?
Old 07-27-2012, 01:10 PM
truckdog62563
There are several "safer" options. Cheapest is to find a set of "lock ring" 20" wheels at a local yard. There were many outer rim designs made over the years, and some of the lock ring variety are still in production for some applications, and can still be serviced. Finding them with your 5 lug x 8" pattern might take some yard searching. These will be tube type like your widow makers. Tubeless wheels were introduced in 1956 which eliminate all the hassles with multi-part rims. The exact replacement for a 20" tube type is a 22.5" tubeless. These are hard to find and tend to be expensive when found. The other option is a 19.5" tubeless. These are comparable to 17" tube types which will thus use a shorter tire, but they fit and work well on these trucks if road speed isn't your first concern. There are two sets of these for sale in the classified section here. I'll leave it at this, and suggest that you do your research on Google for "lock ring" wheel design information. If you find a set, or make a set from several different donors, be certain to keep the rings and rims together as matched sets. Mix matching rims and rings can be as deadly as the widow makers. Stu
Vinford
Fifth Wheel & Gooseneck RV Towing
39
12-15-2016 07:56 AM
PwerStroke99
2017+ Super Duty
08-04-2016 08:47 AM
willowbilly3
06-10-2016 09:17 PM
DK-F100
08-20-2014 07:00 PM
JMILLE3
23
12-21-2009 07:55 PM
Quick Reply: Ford 1949 F5 Wheel
