Ford unibody mustang 2 install - Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Old 09-25-2010, 11:51 AM
Fastlane1's Avatar
Fastlane1 Fastlane1 is offline
Fastlane1 is starting off with a positive reputation.
Ive been working on my 61 uni alot lately and I got my mustang 2 and I need to figure out where the stock center location is for the front wheels. I also want to move it forward to center the wheels in the fenders. My truck had a volare front end in it and the cut ALOT of the frame out. I remade the frame from the cab mounts forward. Any input is appreciated.
Old 09-25-2010, 11:57 AM
Fastlane1's Avatar
Heres a pic of my uni.
Old 09-25-2010, 04:20 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
Stock is 114 inches from the center line of the rear axle. Measure up 115 and that will give you the inch of stretch. You can also use the upper clutch mount bolt blind nut. This to center line will be approximately 12 1/2 inches give or take a bit forward of this for a 115" wheelbase.
This will better center the front wheel in the fender well. Most kits are designed to do this.
Garbz
Old 12-02-2011, 02:43 AM
62RatRod 62RatRod is offline
62RatRod is starting off with a positive reputation.
Has anyone tried using a later model trans am subframe? My buddy has a wrecked one and i was thinking about conning him out of it
Old 12-02-2011, 11:23 AM
garbz2's Avatar
Take some measurements before picking it up. The body stubs are way wide wide on those GM stubs.
Garbz
Old 12-02-2011, 05:17 PM
Ok thanks I'll look into it.. What about just using the control arms and building the shock towers?
Old 12-03-2011, 02:05 PM
garbz2's Avatar
It will all be custom work, quite frankly not worth it as the chevrolet design will interfere with the common ford oil pans.
Remember Chevys have the oil pump in the rear allowing a real shallow front pan. The only ford motors with a similar profile is the new modular 4.6 and 5.4s. you really have to set the ford engine high in the bay to accommodate this design.
Garbz
03 Crown Vic IFS Install in 54 M100 4mrdragoon 1948 - 1956 F1, F100 & Larger F-Series Trucks 91 06-15-2015 05:31 AM
Mustang II Crossmember centerline Question Daniels54 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 06-11-2015 09:53 PM
Installed Daystar 2" Leveling Kit. wht250 1999 to 2016 Super Duty 0 06-02-2013 08:37 PM
53-56 front wheels set far back devof100 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 05-15-2012 04:46 PM
Installing TCI Mustang II IFS Jeff55F100 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 08-30-2005 01:14 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
12, 1962, 61, 63, brakes, end, f100, ford, front, installation, mustang, mustang2, older, truck, uni, unibody
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
