Popping and grinding
09-24-2010, 08:46 PM
when the truck is moving slow with the wheel turned to the right from about half way to full lock i get the popping jerking and grinding sound it sounds like it's coming from the back anyone have clue what it could be
09-24-2010, 08:51 PM
on
Differential?????
Maybe it is a LS rear end and it is low on gear oil?
09-24-2010, 09:04 PM
It is a 4.10 LS rearend i have not check the oil yet it was dark when i got home
09-24-2010, 09:11 PM
on
It could be that the level is low, or maybe it doesn't have the friction modifier additive in it?
09-24-2010, 09:31 PM
I went checked the oil and it's way over full as soon as i pulled the plug oil just start's dumping out what next
do i drain the oil and refill with new oil and friction modifier additive
09-24-2010, 10:55 PM
on
fordpride,
I have two articles I want to send you on frame noise but I don't know how to attach them. I just sent you a PM with my email address, shoot me an email and I will send them to you.
Kevin
09-24-2010, 11:48 PM
yep i think it's the rearend UCK
09-24-2010, 11:51 PM
on
09-24-2010, 11:54 PM
09-24-2010, 11:57 PM
on
really... if the LS is bad, you can have the one out of my dually.
09-24-2010, 11:58 PM
Thanks i going to drain an refill tomorrow and se what happens
09-25-2010, 12:00 AM
on
what is the best additive? when i refilled mine after the swap, every bottle i looked at said... LS compatible.
09-25-2010, 12:01 AM
How many qts. of oil did it take to refill yours
09-25-2010, 12:02 AM
i'm going back regular oil and motorcraft additive
09-25-2010, 12:03 AM
on
just over thr33. i just read your post again, does it only make noise on right turns?
