water pump
not a bad job, fan clutch kinda sucks. Need a big wrench and shock it with a hammer, or an air hammer, or rent tools for it at the auto parts store. Otherwise, not too bad.
http://ad.doubleclick.net/click%3Bh%...?siteid=214072
He carries oem pumps, quite a bit higher but better quality. Just thought I'd let you know that, you can go with a cheapo at the parts store if you wish. I went with a cheapo, I'll see how long it lasts. If it is short lived, I'll pay more next time for oem.
Just changed mine 2 weeks ago. Not a bad job. Got pump from Autozone as well as fan clutch wrenches. Only bad thing I was visiting my daughter in Georgia but I pack enough tools to almost do a overhaul when I travel. Got some strange looks from people living in the apartment complex. Just be sure to check the coolant with the test strips when you are finished.
I've done two in the last week, (different trucks) and yes like everyone else said it is not to bad.
I did make the rookie mistake with the first one... I let some antifreeze get on the belt....sqeal.....forever....well it finally quit.
I have never gotten the fan clutch wrenches, I just carefully use an air hammer and use a large channel lock pliers to tighten it when I am done.
Good luck!
Good luck!
