2003 6.0 missing/idling rough - Ford Truck Enthusiasts Forums
Old 09-24-2010, 05:05 PM
TChap6liter's Avatar
TChap6liter TChap6liter is offline
TChap6liter is starting off with a positive reputation.
Ok guys, im having some trouble. I have an 03 powerstroke 6.0, and for some reason it runs really rough. I replaced my ICP sensor and wiring harness then updated my computer and that didn't fix it. I took it to a shop and they told me my #1 and #7 injectors were bad, so i replaced them. no change. When it idles, it acts like it misses, and when you drive it down the road it shakes and misses for about 20 minutes, then it stops. Im not sure what else to do. I stretched my fuel regualtor spring to try and get more pressure but that didn't work either.
Old 09-24-2010, 07:16 PM
brickie's Avatar
brickie brickie is offline
brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.
I had a miss in my 350 a few years back,took it to the dealer(last dealer visit) 2200 bucks later I still had a miss.Dealer was getting injector codes but once replaced with new injectors the code came back.So I replaced 8 injectors with aftermarket and low and behold I still got a GD miss.I posted here about my trouble and either Blackhat or Bow Tie Hater Told me it was the HPO rail check valve, so I swap them out and the miss is gone never to return.
Old 09-24-2010, 11:52 PM
Thanks man. sure hope that does the trick. how much does that check valve run? And how hard is it to change? Is there one on each side of the engine or just one for both sids?
Old 09-25-2010, 12:47 AM
brickie's Avatar
One on each oil rail I think they were about 60 bucks each.It isn't a difficult job if you have been under the valve covers before. Page 40: Fuel Management System
Old 09-25-2010, 09:28 AM
Ok Thanks. Yeah, I have had the valve covers off before when i changed my injectors, but I never thought about it being in my HPO system. I sure hope this does the trick. I'll be sure to let you know how it does.
Old 09-25-2010, 10:29 AM
brickie's Avatar
I hope it does the trick as well as it did for me.
Old 09-27-2010, 11:50 PM
OK so I called my local ford dealer today and told them that I needed a high pressure oil rail check valve and they couldn't figure out what I was talking about. I had to go to them with the picture and show them and the said it was called an oil fitting on their computer. It was $65+tax. It will be in tomorow morning, so tomorow afternoon I will pull it apart and change it out. Hopefully this will fix my missing problem. I'll be sure to keep you posted.
Old 09-28-2010, 12:16 AM
brickie's Avatar
Quote:
That's funny,I had to show the dealer parts guy the part on his computer screen when I went in as well,
Old 09-28-2010, 04:10 PM
Hey did you change the part or did somebody else?
Old 09-28-2010, 05:15 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
IF that doesn't fix the problem... PM me and let me think of something else.
Old 09-28-2010, 07:48 PM
brickie's Avatar
I did them myself.
Old 09-28-2010, 08:59 PM
Well how did you get the high pressure oil line off of the fitting? It calls for a special tool but is there a way around it?
Old 09-28-2010, 11:48 PM
Fallguy2004's Avatar
Fallguy2004 Fallguy2004 is offline
Fallguy2004 is starting off with a positive reputation.
Quote from Cheezit, when he answered my same question.
"use a 1/2 collet wrench. the one from my diegrinder works great."
And P.S. it works very well!!!
Old 09-29-2010, 01:54 PM
Ok am I doing something wrong?? Should the fitting just pry off? Because I can't seem to get it off no matter what I try...
Old 09-29-2010, 01:57 PM
I'm talking about the connector on top of the fitting, not the part that threads into the oil rail
6.0 Code P0269, Intermittent rough idle, smoke... Codeman894 6.0L Power Stroke Diesel 9 03-05-2017 06:41 PM
Very rough idling Diesel big-head 1999 to 2016 Super Duty 2 08-03-2015 10:20 PM
f350 6.0 running rough tuskfire8 Texas Chapter 5 11-29-2012 02:51 AM
6.0 Rough Idle @ Stop in Drive Gear (Automatic) whutch42 6.0L Power Stroke Diesel 8 01-11-2005 03:48 PM
6.9 flooding... 73Custom 1999 - 2003 7.3L Power Stroke Diesel 13 03-24-2002 04:31 PM
Tags
1994, 2003, 2005, 60, arowstar, diesel, f350, ford, idoling, missing, powerstroke, ride, rite, van, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
