To anyone that has put a SBC or SBF in a 1951-52 F-1
Old 09-25-2010, 01:37 AM
lvin4jc's Avatar
lvin4jc
lvin4jc is offline
Originally Posted by 52 Merc
Unfortunately, no. And the truck is long gone. But they are easy to build. All it takes is a piece of plate steel to box a small area of the frame, a piece of 3" square tubing to use as an upright, a piece of small round tubing for the motor mount bolt to go through welded to the top of the square tube and you're in business. Install the engine in the location where you want it and build the mounts to fit. It's custom fabrication, but it's certainly not rocket science.
Sure, that sounds simple enough.
Originally Posted by ibuzzard
Off with his head!
sbc, not cool. I'll grab my pitchfork and light a torch.
Old 09-25-2010, 07:59 AM
canadian_diesel1964's Avatar
canadian_diesel1964
canadian_diesel1964 is offline
Thats damn funny guys!!!I am smiling!!
Old 09-25-2010, 04:44 PM
lvin4jc's Avatar
lvin4jc
lvin4jc is offline
We're not smiling, seriously, please put a Ford engine in that thing.
Old 09-25-2010, 05:07 PM
canadian_diesel1964
whats a good Fuel Injected engine to put in thats ford? its still possible to change my mind!
Old 09-25-2010, 06:52 PM
canadian_diesel1964
One more question, when we change the motor...where is the best place to get the new rad as there would be no need for 2 water pumps etc?
Old 09-25-2010, 11:27 PM
lvin4jc's Avatar
lvin4jc
lvin4jc is offline
I'm putting a 302 in mine, i'm pulling the EFI off, but you could sure keep it on your project. Or the 351 or the 390, 460... Quite a few ppl on here recommend the 351w and it is a really good engine with lots of potential, i'm just partial to the 302.
Two water pumps???
Old 09-25-2010, 11:38 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,410 Likes on 1,370 Posts
You can't go wrong with an 87-95 302 (5.0) They're cheap to build and have a ton of aftermarket support. The later 4.6 OHC or DOHC engines are a little more high tech if you want to go that route. They've been around now for 20 years and have a great reputation for being pretty much bulletproof.
Old 09-25-2010, 11:47 PM
lvin4jc's Avatar
lvin4jc
lvin4jc is offline
What's the deal with the '95-'96 change? I bought a '96 but all the cool parts I want in the catalogs are for '95 and older, is it the roller cam or what's the difference?
P.S. I know you're a Merc fan so i'll mention that I just got back from riding in my friends '68 Cougar, that's a fun ride.
canadian_diesel1964
Thats good info...sorry I meant 2 water pumps on the 239 ...need to go to 1 intake and one out put...
Old 09-25-2010, 11:50 PM
lvin4jc's Avatar
lvin4jc
lvin4jc is offline
I guess a lot of guys swap in the radiator from the 6cyl (one in and one out). I have one that i'm not going to use but I don't know if shipping it to Canada would be as much fun as i'm thinking it would.
Old 09-25-2010, 11:55 PM
canadian_diesel1964
I have a place in Michigan 48060 that I ship stuff to...is it a good one or does it need a recore?
Old 09-25-2010, 11:57 PM
lvin4jc's Avatar
lvin4jc
lvin4jc is offline
I don't know, all i've done to it is flushed it out with a hose and if you hold the bottom hole shut it'll fill up to the top without leaking, but that's not under pressure of course. I think this truck has been on the road fairly recently so it could be either way I suppose.
  #28
Old 09-25-2010, 11:58 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
1995 was the last year the traditional 5.0 engine was used in the Mustang. But it was still used for a few more years in the Explorer. In that application, the engine used a unique water pump, intake manifold and heads. Probably a few other little things, too. But the basic engine itself is the same. What "cool parts" are you looking to use?
  #29
Old 09-26-2010, 12:04 AM
canadian_diesel1964
I was noticing on LMC that they have them new from 249.99..not too bad at all....what do you think about a 1984 302 with a T-5 already rebuilt and ready to go? do you think there would be fitment issues?
http://windsor.kijiji.ca/c-cars-vehi...dIdZ223686873#
  #30
Old 09-26-2010, 12:16 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
REBUILT 5.0 HO T5 TRANNY CENTERFORCE CLUTCH - Windsor Region Engine, Engine Parts For Sale - Kijiji Windsor Region Canada.
The year of the engine isn't as big a deal as what comes with it. The only real downside to the 84 is it'll have a flat tappet camshaft. The roller cam was introduced one year later, in '85.
The Mustang T-5 will be a difficult fit from the sense the shifter will be set back farther than most people would be comfortable with.
Quick Reply: To anyone that has put a SBC or SBF in a 1951-52 F-1
