I recently built a new motor and changed my mind on cam selection due to change of plans for motor. I have a brand new FMS double roller timing chain. This chain is super tight and has almost zero play. I have removed the cam sprocket bolt and have tried to slide the sprocket off the cam but it tightens up before coming off the cam, I think because the chain has almost zero slack. The bottom crank cog will not budge by hand. Anyone have any tricks or ideas?
Try a large screwdriver behind the crank gear to gently wedge it forward and then try to
remove the cam gear. You may have to move it a couple of times to get it where the
cam gear will come off.
