F600 Question
F600 Question
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1 itxtvisited="1"> <!-- / icon and title --><!-- message -->
Could someone please tell me difference in size of the front clip between a 56 f100 & a f600? Is it just the wheel wells or other dimensions. I was told the f600 was wider. If so where is the width different? Where there more than 2 sizes of fiont ends. I am working with a 55 school bus f-600 but I think it has a 56 front end on it. Will a nose from an f100 fit a f600? Thanks
I have found a tilt front end I was thinking about getting. The guy is telling me it has the larger wheel opening for a f600. He also says it is 4 inches wider. Seems odd that someone would make a fiberglass front end for the larger trucks. I have not physically seen it yet. I took the fender off of the bus and compared it to a f100 fender and it looked like wheel opening was not in the same place. There's no way the fenders would have been different because it was a bus is there?
Received 4,132 Likes
on
The overall shape of the fenders between the f100 and f600 are the same. To make the wheel well opening larger they moved the opening a little larger both forward and back. The back portion of the fender also is a couple inches longer to attach the the running boards. The width between the f100/f600 are the same. It's not until you get into the big jobs that the fenders get any wider.
