Folding the rear seatback (crewcab) - Ford Truck Enthusiasts Forums
Old 09-24-2010, 06:33 AM
rlh68050's Avatar
rlh68050 rlh68050 is offline
rlh68050 is gaining momentum as a positive member of FTE.rlh68050 is gaining momentum as a positive member of FTE.
Looking at the service manual it seems that the rear seatbacks fold down allowing access to the back cab panel. You can see and feel the latch when you raise the cushion (look behind and down from the headrest). You need to pull up on the latch to release the back from the cab panel. This is from the service manual:
The Crew Cab rear seat is a 40/60 split bench style with folding cushions and optional folding armrest with cup holder. The backrests are fixed to the rear cab panel by latches that can be accessed from behind only for service allowing the backrest to fold down. The backrest latches are accessible only when the seat cushion is folded upright.
Release the backrest latch.
From behind the backrest, pull up on the latch release and pull the backrest forward.
Release the cushion latch and lower the cushion and backrest.
I tried to pull up on the latch but cannot get it to release. Has anyone been able to do this? I want to install an amp behind there so I need access.
Old 09-24-2010, 06:54 AM
shotgunz's Avatar
shotgunz shotgunz is offline
shotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to all
Old 11-04-2010, 08:19 AM
deltaboost deltaboost is offline
deltaboost is starting off with a positive reputation.
Is anyone worried about the amp getting too hot being sandwiched between the seat and rear wall?
Old 11-04-2010, 10:27 AM
2010PLATINUM's Avatar
2010PLATINUM 2010PLATINUM is offline
2010PLATINUM is starting off with a positive reputation.
I was thinking the same thing about the heat issue
Old 11-04-2010, 11:38 AM
I was worried about my last amp (only a 500 watt) that was bolted to the rear wall of a regular cab. It got so hot I thought it might be a fire hazard with the carpet back there. And that had around 6-8" between the seat and the amp. I couldn't imagine just sandwiching it between the seat and rear wall...seems like it would go into safe mode quite quickly...
1992 F-150 Extended cab seat cable hiredgun 1987 - 1996 F150 & Larger F-Series Trucks 4 02-10-2017 05:54 PM
Will these seats bolt in? Shovelheadrob 1999 - 2003 7.3L Power Stroke Diesel 1 09-04-2015 12:50 PM
Back Seat Release Strap Pre-Electrical Modular V10 (6.8l) 2 09-20-2014 09:54 AM
SuperCab owners, does the back seat-backrest flip down? Pool Runner 2009 - 2014 F150 12 03-12-2013 09:12 PM
Most comfortable bucket seats? grapegravy 1973 - 1979 F-100 & Larger F-Series Trucks 12 12-19-2003 01:18 PM
Tags
2010, backrest, backs, cab, crew, f150, fold, folding, ford, forward, instruction, rear, seat, seatback, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
