94 ranger stalls right after starting. - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 09-23-2010, 10:28 PM
teejmac teejmac is offline
teejmac is starting off with a positive reputation.
I have a '94 4 cylinder manual ranger. Recently my truck will randomly stall right after I turn the key to start it. It is not all the time but it happens enough that it is affecting my daily routine. The starter pushes out and turns over and then it stalls right after. I recently changed the fuel pump thinking maybe I am not getting enough gas for it to start. Well, i changed that 3 days ago and I am now stuck with my truck stalling out again.
Has anyone else had this problem or have any ideas because I am out of ideas.
Thanks guys.
Old 09-24-2010, 12:21 AM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
Starter needs new brushes, they are about 3 dollars, or you could get a new starter.
Old 09-24-2010, 03:20 AM
michigan66's Avatar
michigan66 michigan66 is offline
michigan66 is gaining momentum as a positive member of FTE.
What is stalling? Is it the starter or the engine?
There is a Schrader valve on the fuel line toward the rear of the engine (driver's side) that you can use to check fuel pressure.
You indicate that you replaced the fuel pump. Did you also replace the fuel filter? That could also reduce fuel pressure.
Do you hear the fuel pump run before the starter engages?
Old 09-24-2010, 07:06 AM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
Thanks guys.
what does stalling me..........when i think of stalling i think you start the car it runs for a little bit and then it dies.........is that what it does...................Post the results of the fuel pressure test you did before you changed the fuel pump...
Old 09-24-2010, 08:47 AM
pawpaw pawpaw is online now
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Welcome to FTE.
Don't throw any more parts at the problem until you have a positive diagnosis result.
Further clarification on the wording description of the problem would be helpful.
From your having replaced the fuel pump, I take it that it's a problem with the engine starting, but then stalling & a number of things can cause that, like an acting out IAC, fuel pressure regulator, fuel pump or electrical connections/power to it, so the ignition switch, fuel pump power relay, inertia switch, electrical connectors & wiring to the pump belong on your suspect list, along with a clogged fuel flter or crimped fuel line, ect, ect.
Have you been having any other idle, or driveability, or lack of engine power, or engine stalling problems at idle, during a drive cycle????
As has been said, a KOEO & KOER fuel pressure check at the fuel rail would be good info, as well as the fuel filter replacement question.
If you don't have a fuel pressure gauge, have you at least pulled the vacuum line to the fuel pressure regulator, to see if it's wet inside with fuel???? If it is, suspect the pressure regulators vacuum diaphragm is bad, so the regulator will need to be replaced.
Do you have a CEL lit????
If so, pull & post the computer trouble code Numbers, as they can offer up good trouble shooting clues.
A bunch more thoughts for consideration, let us know how it goes.
1986 Random Stalling and Unable to Pull Codes Lzryde 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 03-24-2015 09:38 AM
1985 ford bronco with new carburetor stalls out animal2b 1978 - 1996 Big Bronco 11 03-04-2015 05:19 PM
94 Ranger won't start on incline wanta79 Ranger & B-Series 5 01-29-2012 09:27 AM
2006 F350 5.4 stalling issues Dreamer99 1999 to 2016 Super Duty 6 12-14-2008 05:30 PM
91 ford ranger 2.3L stalls BigBertha Ranger & B-Series 4 10-21-2005 01:15 AM
Tags
29, 40, 94, braking, engine, ford, heaving, randomly, ranger, stall, stalling, stalls, start, starting, startup, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
