Code p2195 (Bank 1 sensor 1 O2 sensor stuck lean) - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-23-2010, 06:52 PM
itswillist itswillist is offline
itswillist is starting off with a positive reputation.
So I just replace my Cat. Converter with all new sensors in them. I just replaced my spark plugs. (I'm knocking out these check engine light problems) and I think I'm getting close to the root as to why these other parts went bad.
Can anyone tell me why my o2 sensor would be stuck on "lean"
Any help would be great !
Old 09-23-2010, 08:25 PM
jpastor1759 jpastor1759 is offline
jpastor1759 is starting off with a positive reputation.
check for an exhaust manifold leak my 05 had that same code for awhile before i noticed the leak. In my case 2 of the bolts broke and the manifold warped and needed ti be resurfaced.
Old 09-23-2010, 08:38 PM
Yeah the truck seems to "miss" here and there but it runs and idles great 95% of the time. I'm not sure if it's a "miss" or a fuel injection issue. But the code p2195 has me thinking it's something in the vaccum or fuel system. The code says the o2 sensor is stuck on Lean .. Should I focus more on a fuel issue or an exaust/vaccum issue ? I'm just ready to have this thing fixed. I believe the previous owner let it run like this for a while thus ruining the cat converters, sensors, and spark plugs. I have now replaced all of these things and each time I fix something a new code pops up and the current code is p2195 I'd like to get this issue fixed as not to harm the cats and sensors I just bough (Motorcraft and oem cat converter.. no cheap to say the least 20$ a piece for spark plugs !
Old 09-25-2010, 10:09 AM
takotruckin takotruckin is offline
takotruckin has a good reputation on FTE.takotruckin has a good reputation on FTE.
A P2195 is usually a bad O2 sensor. What brand did you use?
Generally on a Ford, a vacuum leak or fuel issue with result in BOTH P0171 and P0174 codes.
Old 11-29-2010, 10:58 PM
charise07 charise07 is offline
charise07 is starting off with a positive reputation.
Hi,
I know this post is a couple months old but if you havnt yet resolved your issue I have some info for ya. P2195 is NOT usually a bad o2 sensor. You are absolutly on the right track with thinking it has to do with fuel/vacuum issues. This is almost always the case. Just yesterday I was working on an 03 4.6l expedition with multiple o2 sensor codes including p2195 which would occasionally start to shake a little at idle. I was totally stuck on a fuel delivery problem and since it was only pulling lean on bank 1 I rulled out fuel pump/filter. Also most (not all) vacuum leaks will pull bank 1 and 2 unless its in the intake manifold effecting individual cylinders. My issue turned out to be a fuel injector going out. I diagnosed this issue by unplugging the electrical to each injector one at a time and testing the actual injector's resistance with my digital voltmeter. All the injectors were reading at between 16.2 and 16.8 except for one which was 14.4. With a bad coil an injector cannot produce the proper spray. Now if its not a bad coil (bad resistance) it can be clogged. Most people use injector cleaner but my mechanic genius friend swears by (and has used many many times) 1 quart of ATF (I know it seems crazy) in the gas tank with at least 15 gallons of gas, and yes its perfectly safe for your entire fuel system as long as its diluted enough. If its not an injector it could also be a dirty mass air flow sensor which can just easily be cleaned with maf sensor cleaner or electronics cleaner, nothing else. If you think your maf is not working you can always use your trusty digital voltmeter to check that as well. If neither of those are the culprit than just spay the engine down on all the vacuum lines and intake manifold with carb cleaner and listen for the rpms to rev to possibly find a vacuum leak. There are a couple other possiblities but these are the most common. Yes an exhaust leak would pull that code as well but you should be able to hear that pretty easy. Hope this helps.
ps, after changing anything if you dont want to wait till a code pops up to see if you fixed it you can always climb under the car and manually check the o2 sensor readings with a digital voltmeter while the vehicle is running and is warmed up. On most o2 sensors that have 4 wires, you test the black one. The gray wire is ground and the 2 white wires are to heat the sensor. Make sure your black probe on the voltmeter is grounded to something like your frame. Proper upstream (pre-cat) readings should constantly fluctuate widely between .1 and .9, lean will fluctuate only in the .1-.3 range and rich will stay in the .7 - .9 range. Again this does not mean you have a bad sensor.
Other possibilities: pcm or egr issues.
code p2197 thunderbird1986 1968-2013 Full Size Vans 3 10-21-2013 07:30 AM
Success story, Check Engine Light, P2197 F150Terry 2009 - 2014 F150 12 01-15-2013 05:10 PM
Keep getting 2 codes 03scf250 General Automotive Discussion 5 10-04-2009 06:58 PM
Oxygen sensor replacement jokerswild130 1997-2006 Expedition & Navigator 7 10-20-2008 07:24 AM
O2 Sensor Problems Persist applehead 1987 - 1996 F150 & Larger F-Series Trucks 20 12-08-2007 11:49 PM
Tags
1o2, 2004, bank, check, code, engine, escape, ford, lean, o2, p2195, sensor, sensors, signal, stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
