'97 F250 diesel oil change ?? - Ford Truck Enthusiasts Forums
Old 09-23-2010, 12:44 AM
kevinrea kevinrea is offline
kevinrea is starting off with a positive reputation.
hey guys,
i am going to go get an oil change on my '97 F250 diesel in the next couple of weeks.
how many quarts of oil does this thing hold?
is the oil filter a spin on/off or a canister?
what brand of oil do you guys like ?
i have always used castrol and/or valvoline in most of my cars.
thanks,
Kevin Rea
Palmdale, Calif.
Old 09-23-2010, 01:42 AM
dieselstreamer's Avatar
dieselstreamer dieselstreamer is offline
dieselstreamer is starting off with a positive reputation.
I just changed the oil in my 97 7.3
The book says 15 quarts, but mine is solid at the full mark with 14
my oil filter is a spin off, but be careful when it is full of oil, it is heavy and hard to hold on to, don't ask me how I found that out.
I rigged a funnel on a 5 gallon can to catch the oil, or use a open can but don't loose the plug.
make sure you use a GOOD oil made for diesels, these are too expensive to fix, just to save a few bucks at oil change time, and I have been warned not to stretch out the oil changes.
This is my first diesel, so I am trying to do every thing right.
Old 09-23-2010, 05:54 AM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Ya, mine holds 14.5 approx. I run rotella 15/40 as do lots of guys. Some run motorcraft, some delo, some synthetic. Motorcraft fl1995 I think is the number for the filter. I've been told to change at 3000 miles, especially if you work the truck hard. You could probably go to 5000 with just highway driving. Jim at rosewood diesel wrote to change at 3000 miles so that's what I do...
Old 09-23-2010, 06:03 AM
Copedawg's Avatar
Copedawg Copedawg is offline
Copedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant future
ditto above. Due to HARD lessons learned: I would make sure you have a drip pan large enough to catch all the oil AND try to put a large box or droop a large heavy blanket on the "wind side" of the truck to combat the wind blowing the oil all over the place/face, hair etc...
It isn't to difficult, you should be able to do it from start to finish in about 20 minutes or so.
Oh, and don't forget to check the filter for tightness before and after the truck is warm/operating temperature.
Old 09-23-2010, 08:02 AM
jeep1947 jeep1947 is offline
jeep1947 is starting off with a positive reputation.
Take a punch and drive it in bottom of filter then u can drain oil and filter at the same time. Makes it a ton easier to remove the filter. Also remember to fill the filter with oil before you put it back on. If not u run the risk of loosing a bearing due to the large filter and the time it takes to fill it and get oil pressure to engine. Good luck.
Old 09-23-2010, 11:49 AM
Copedawg's Avatar
Quote:
Great idea! I will try that next time.
Thanks!
Old 09-23-2010, 12:13 PM
triskadek's Avatar
triskadek triskadek is offline
triskadek is starting off with a positive reputation.
I now just expect to get bonked in face with a hot messy oil filter.
Old 09-23-2010, 12:20 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
Quote:
Poke a hole in it... I take a big nail and a hammer under there with me. A couple good raps and you're done. Makes things so much nicer! Also consider a Fumoto valve... one flick of the lever to drain the oil.
Old 09-23-2010, 01:55 PM
thanks for the info guys..
so, i know what to expect when i take it to get an oil change.
too old to do that stuff myself.
i already did hundreds of them in the past.. don't want to do them any more.
kevin
Old 09-23-2010, 02:41 PM
triskadek's Avatar
At least put take a sharpie type permanent marker to your old filter...so you can shove it in their face when you take it back because they charge you but don't bother to actually replace it...
Old 09-27-2010, 06:28 PM
summet20's Avatar
summet20 summet20 is offline
summet20 is starting off with a positive reputation.
Have used Rotella 15w 40 since new on my 1996 F-350 CC 4x4 and am now reaching the 300,000 miles. I do use a motorcraft filter though. It takes 14quarts.
Alot of guys use this combo on their 7.3's and more.
Old 09-27-2010, 08:59 PM
dturnersr's Avatar
dturnersr dturnersr is offline
dturnersr is starting off with a positive reputation.
A good sharp punch...give it five minutes to drain. Absolutely, fill that new filter before putting it on...as with anything you change. It's the little things that are important.
I've used both Motorcraft and Shell, but I like the Motorcraft 5 qt jugs best. Fl-1995 is my mainstay. I have been changing my ever 5K, but under severe duty 3K is the ticket, an expensive ticket, but better that the alternative
Old 09-28-2010, 07:14 AM
jmgekeler jmgekeler is offline
jmgekeler is starting off with a positive reputation.
This brings up a question in mind. With the weather starting to turn cold, what weight oil do you all run? Winter in Indiana usually runs 10 to 30 degrees.
Old 09-28-2010, 07:24 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
Brown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud of
Quote:
If you can afford it, run a good 5W40 synthetic, like Rotella or Amsoil. Faster starts, and some have reported MPG increases as well.
Injector Pressure Doc Wright 1994.5 - 1997 7.3L Power Stroke Diesel 11 02-27-2017 08:36 AM
New Purchase Tune-Up Recomendations VEightFreak24 1994.5 - 1997 7.3L Power Stroke Diesel 12 02-16-2017 12:51 PM
'97-F250-7.3L diesel....fuel filter location ??? kevinrea 1994.5 - 1997 7.3L Power Stroke Diesel 17 09-22-2016 09:21 AM
97 F250 rear brakes full of oil narfzort Brakes, Steering, Suspension, Tires, & Wheels 6 12-28-2015 07:28 AM
change oil pan gasket Bigal700 1994.5 - 1997 7.3L Power Stroke Diesel 11 05-09-2014 11:49 AM
Tags
1996, 1997, 97, 97n, air, capacity, change, diesel, f250, f350, filter, locations, oil, oils, powerstroke, quarts, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
