Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 09-23-2010, 12:25 AM
rob71185 rob71185 is offline
Garage is empty, add now
rob71185 is starting off with a positive reputation.
2007 Expedition not starting
Hey guys, I was a member years ago and y'all helped me with my truck and saved me a lot of money in the long run so now I'm searching for help for my grandparents. They have a 2007 Expedition, with all the features, (can't remember what model but I'll update later, navi, leather and all that stuff) After they got gas today they drove home and stopped at the mailbox, took the key out of the ignition got the mail then put it back in and tried to start it. Nothing happened, didn't barely turn over, didn't click it was just quiet. Battery power was in tact though so I know it's not that, but just in case I disconnected it (and hopefully restarting the alarm just in case it was that but it wasn't that either). I didn't hear the fuel lines or anything. I thought it might be a computer issue, alarm kill switch issue or something like that. Hopefully y'all might have an idea before we waste a bunch of money at a mechanic. thanks guys!!
  #2 (permalink)
Old 09-23-2010, 10:32 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
I have had this happen before on my 07 I owned. A glitch or gremlin. All I did was pull the key wait a second and try it again.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 09-23-2010, 12:07 PM
Yea we tried that too. I wish it would have been that easy.
  #4 (permalink)
Old 10-14-2010, 01:29 PM
DavidB67 DavidB67 is offline
DavidB67 is starting off with a positive reputation.
We just got our 2007 Ford Expedition Limited back from the Ford dealer; they had it in the shop from 14 Sep - 11 Oct 10!!! The mechanics were idiots. The initial problem was that the truck would crank, but not start. After about 3 weeks of "checking everything" they decided to replace the engine control module. It didn't fix the problem. They ended up flying in a Ford tech; he couldn't figure it out. They flew in ANOTHER Ford tech and he determined that it was most likely the fuel pump. The dropped the gas tank and found that the fuel pump had melted to nothing and the cabling going in and out stretching about 1-1/2 foot away had melted. Per the Ford tech; "You're lucky you had a full tank of gas, otherwise the truck probably would have exploded." When asked what caused the failure, their response; "We have no idea". They also replaced the control module; which had also failed. They socked me with a $1310 bill to replace the fuel pump. The control module was replaced under warranty to "help me out" after the fuel pump bill. I'm trying to find out what exactly the engine control module controls. My opinion is that it was most likely what caused the failure of the fuel pump. There were other indications of electrical system failure such as my wife plugged her cell phone charger in the outlet and it turned the A/C off - this was fixed when the control module was swapped.
Tags
01, 2007, ac, cranking, expdition, expedition, ford, fuel, kill, melted, problem, pump, starting, switch, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
