2005 F150 4wheel drive rear rotor removal - Ford Truck Enthusiasts Forums
Old 09-23-2010, 12:54 AM
degbert degbert is offline
degbert is starting off with a positive reputation.
How can I get the rear rotors off. Pounding with no luck, do I have to release the parking break somehow?
Old 09-23-2010, 04:13 AM
svt2205 svt2205 is offline
svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.
You may need to back off the parking brake shoe's. There's an access plug on the bottom portion (around 6 oclock) on the backing plate.
Old 09-24-2010, 07:10 PM
Wilber15 Wilber15 is offline
Wilber15 is starting off with a positive reputation.
I have seen them rust to the axle and have had to crack them in half to get them off. But your most likely culprit is a very thick rust ridge around the inner edge of the rotor causing the e-brake shoes to hang up. Like stated above, back the e-brake shoes off and it should slide right off.... Otherwise, find a BFH and crack the rotors in half if they are actually rusted on solid.
Old 09-26-2010, 06:34 PM
BatteriesNotINCL's Avatar
BatteriesNotINCL BatteriesNotINCL is offline
BatteriesNotINCL is starting off with a positive reputation.
Sometimes you find the locking ring on the studs themselves. Mine had 2 on the rear driver side.
Rear disc brake rotors arkredneck 1978 - 1996 Big Bronco 3 02-14-2016 09:44 PM
Seized rear rotors BoydGilley 2004 - 2008 F150 3 12-02-2012 10:04 PM
Napa Rotors Ex Factor Excursion - King of SUVs 27 03-29-2011 08:06 AM
2005 rear rotor question BEWOLD 2004 - 2008 F150 1 08-25-2009 11:10 PM
Minimum Rotor thickness? cangim 1999 - 2003 7.3L Power Stroke Diesel 2 02-22-2006 09:34 AM
Tags
2004, 20042008, 2005, 2006, change, f150, ford, hd, rear, removal, replacement, rotor, rotors, rust, stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
