Time to replace the glow plugs - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-23-2010, 12:43 AM
Powerstroke-7.3's Avatar
Powerstroke-7.3 Powerstroke-7.3 is offline
Powerstroke-7.3 is starting off with a positive reputation.
I have a 99 f250 psd 4x4 and it has over 244000 miles on it with the original glow plugs in it. After spending a year in chicago I realize that they are not working as good as they use to so I would like to replace them. I am just curious if anyone has any tips or recommendations on this process?
Old 09-23-2010, 12:48 AM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
PREMIUM SPONSOR
Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.
PaysonPSD has a good little write up on it I believe. Biggest thing IMO is use Motorcraft only, made in Beru, Ireland. Alot of us has seen issues with others like Autolites.
Old 09-23-2010, 12:51 AM
Do you possibly have a link for the write up?
Old 09-23-2010, 12:59 AM
robles4242 robles4242 is offline
robles4242 is gaining momentum as a positive member of FTE.
HEY! Check your Glow Plug Relay first and make sure its working!
Welcome to guzzle's Stancor GPR replacement Mod Web Page
Old 09-23-2010, 01:01 AM
I just recently replaced the glow plug relay because it completely stopped working.
Old 09-23-2010, 02:26 AM
malodin malodin is offline
malodin is starting off with a positive reputation.
i dont know much about glow plugs other than they are a externally solid metal object that is heated by electrical resistance, so i am wondering if they go bad due to the internal resistance dropping off, or do they stop transmitting there heat from "gunk" build up on them? i guess in short term can the glow plugs be scotch brited off, because my glow plugs work for sure most of the, i just have to let it sit longer than if they were brand new and they seem simple enough to clean off, has this been done?
sorry if thread jack but thought it was a pertenant question to be asked before one spent $8+ on them
i mean after all if i can remove them clean them off so they transmit there heat better and get another 25k+ out of them i think it would be time well spent
Old 09-23-2010, 09:49 AM
th67ss's Avatar
th67ss th67ss is offline
th67ss is gaining momentum as a positive member of FTE.
Here's a GP write-up from tdpower (2nd post). Have not done my GP's yet but looks pretty simple?
Hope my linking skills still work.
http://www.ford-trucks.com/forums/88...que-specs.html
Still looking for PaysonPsd write-up.
....Tom
Old 09-23-2010, 10:11 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
They are basically a very small oven element.
They get hot enough to glow red hot and burn any deposits right off of them when they are working properly.
If they are not heating up, the only recourse is to replace them.
Old 09-23-2010, 01:39 PM
Granny1153's Avatar
Granny1153 Granny1153 is offline
Granny1153 is starting off with a positive reputation.
Old 09-23-2010, 03:33 PM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Hit it!
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
I'm not trying to be a smarty pants but how I see it, once you spend the 3 plus hours in labor pulling and replacing the valve covers and all the stuff in the way of the glow plugs, you might as well spend the $8 and replace them. A new set can last you a good 100k - 200k miles. But stick with the Motorcraft ZD-11's.
Old 09-23-2010, 07:00 PM
camodown's Avatar
camodown camodown is offline
camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.
Glow plugs go bad one of two ways that I know of. They heat cycle and after a certain number of cycles, the coil inside parts making the resistance go to infinity which means, no current will flow. That is why you can 'ohm' them out to find bad ones. The coil has a minute amount of resistance when it is a complete circuit, but a broken circuit won't transmit current. The second way a glow plug can go bad is that it was made with inferior parts, and when the coil heats, there is a certain amount of elongation/distortion of the coil. If it is made with a low grade metal, the coil will touch the main body and short out. Then you have no glow plugs. I guess I kind of think of it as a filament light bulb. The coil is similar to the filament sort of.
Make sure to get motorcraft ones. Non motorcraft ones fail due the coil being subpar, or they can swell and have the tip break off in cylinder.
glow plug relay branden.w Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 07-30-2014 05:54 PM
white smoke on crank ? Glow plug? Guzzo 6.0L Power Stroke Diesel 8 12-08-2013 01:46 PM
Going to replace glow plugs . . . 1'stonraceday 1999 - 2003 7.3L Power Stroke Diesel 7 11-16-2013 05:12 AM
Glow plug question mrsvegan 1999 - 2003 7.3L Power Stroke Diesel 17 10-19-2013 08:26 PM
NGK Glow plugs 99ranger4x4 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 12-30-2008 09:43 PM
Tags
04, 550, 73, 99, duty, f250, ford, glow, performance, plugs, powerstroke, replace, replacing, super, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
