Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > New England Region > Connecticut Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Connecticut Chapter Join Chapter, Leader: StreamlineGT
  #1 (permalink)
Old 09-22-2010, 08:53 PM
jthorngate3's Avatar
jthorngate3 jthorngate3 is offline
1986 Ford F-150
jthorngate3 has a great reputation on FTE.jthorngate3 has a great reputation on FTE.jthorngate3 has a great reputation on FTE.jthorngate3 has a great reputation on FTE.jthorngate3 has a great reputation on FTE.jthorngate3 has a great reputation on FTE.
42209261 Fordx4bronc3545
300 build thread
I thought I might get started with this since I just got the first piece of the puzzle, or at least I hope so. Here's the new carburetor. There will be plenty of pictures along the way.
Click the image to open in full size.
__________________
Josiah
86 F150 4x4 I6(offy DP, Holley 465cfm, EFI exhuast manifolds, walker y-pipe, ARP head studs, D.U.I. HEI distributor) C6-NP208F, 2 1/2" rough country lift, 32x11.5x15 Cooper Discoverer STT
2010 FFH...slowly accepting, MPG helps
  #2 (permalink)
Old 09-23-2010, 04:23 AM
Zookie400's Avatar
Zookie400 Zookie400 is offline
Garage is empty, add now
Zookie400 is a splendid one to beholdZookie400 is a splendid one to beholdZookie400 is a splendid one to beholdZookie400 is a splendid one to beholdZookie400 is a splendid one to beholdZookie400 is a splendid one to beholdZookie400 is a splendid one to behold
performace I6 yaaaaaaaaaaaaaaaaaaa!!!!!!!!!
did you find out what it actually is from the numbers?
__________________
Since light travels faster than sound, some people appear bright until
you hear them speak.
MY YOUTUBE VIDEOS
  #3 (permalink)
Old 09-23-2010, 06:46 AM
1986 Ford F-150
No. The numbers give me nothing. They did somewhat trace back to a different number that was a "renew kit" for an old carter 4 bbl. Not sure how ligit that is though. From everything I have looked at, it is a 390. It's only missing a few things. Ford kickdown and electric choke, that I can tell anyway.
Here's the picture of the other side. Forgot it last night.
__________________
Josiah
  #4 (permalink)
Old 09-23-2010, 10:17 AM
1986 Ford F-150
There are a few things that I don't know what they are, or what they are for. We'll have to take a look at it Aaron.
__________________
Josiah
  #5 (permalink)
Old 09-23-2010, 02:22 PM
Zookie400's Avatar
i dont think you need a kickdown, i never ran one on my bronco or my brothers 250. if you dont like the shifting you can get an adjustable vac. modulator for the trans, or shift it manually if its lugging at WOT.
__________________
MY YOUTUBE VIDEOS
  #6 (permalink)
Old 09-23-2010, 06:16 PM
1986 Ford F-150
Well, the kickdown is only 10 bucks. I'd say it's probably worth it.
__________________
Josiah
  #7 (permalink)
Old 09-23-2010, 08:37 PM
Zookie400's Avatar
do it. when does that arrive?
__________________
MY YOUTUBE VIDEOS
  #8 (permalink)
Old 09-23-2010, 09:45 PM
1986 Ford F-150
Whenever I get the money to order it. Had some more unexpected things come up that required a hefty amount of change! Dang it! I was starting to get ahead again. That's what I get for thinking positively
__________________
Josiah
  #9 (permalink)
Old 09-27-2010, 09:39 AM
1986 Ford F-150
Got info back from Holley after a few emails back and forth. Ended up having to send some pictures so they could determine what carb it was. It's a 4160 465 cfm holley. They came on 64-67 ford 289 engines.
__________________
Josiah
  #10 (permalink)
Old 09-27-2010, 03:23 PM
Towmanjbo's Avatar
Towmanjbo Towmanjbo is offline
1992 Ford F-150
Towmanjbo has a great reputation on FTE.Towmanjbo has a great reputation on FTE.Towmanjbo has a great reputation on FTE.Towmanjbo has a great reputation on FTE.Towmanjbo has a great reputation on FTE.
Have you seen this forum yet?
FORDSIX PERFORMANCE • View forum - 240-300 "Big Block" Six Performance
__________________
Justin
  #11 (permalink)
Old 09-27-2010, 04:09 PM
Towmanjbo's Avatar
1992 Ford F-150
I sure by now you've heard that the late model exhaust manifolds are like headers. When you get them it's not necessary to get the pipes as well Walker makes a pipe setup that works just as good. The part number is WLK-45166. Just be sure to check the openings that bolt to the exhaust manifold since sometimes the manufacturers don't clear them all the way. They may need some grinding to open them up.
Orig pipes:
Walker pipes:
__________________
Justin
  #12 (permalink)
Old 09-27-2010, 04:43 PM
1986 Ford F-150
I am familiar with the fordsix.com forum. There are a few guys here though that have done the same basic build that I am doing, so I have been using those threads for the most part. Most of their info comes from that forum anyway. I didn't know about the walker pipes kit, though I did know about walker being a good place to get the y-pipe.
__________________
Josiah
  #13 (permalink)
Old 10-16-2010, 02:07 PM
1986 Ford F-150
Have some EFI exhaust manifolds on the way. Getting them through a guy here on FTE. Should have them in the next couple weeks.
On another note, changed the oil today. Didn't have any luck finding the rotella-t 10w-30, so I just went to the valvoline conventional, and found some zddp additive. Started by putting a can of sea-foam in the truck, then drove it around for a while. Ran noticeably better, and quieter. Had my brother help me, so that he could start learning how to work on his own vehicles. Started tinkering around with the truck and found the air filter housing to be shaking pretty good. So I tightened the wing bolt on the top. When I pushed down on the assembly, I noticed the truck running differently. Took the air cleaner off, and found the carb to be shaking pretty well. THE SCREWS HOLDING THE CARB TO THE EGR WERE EXTREMELY LOOSE! Unfortunately they are extremely difficult to get to. After standing on my head, and doing some acrobatics under the hood, I managed to get them pretty tight. Needless to say, it is running quite a bit better. It was a successful day under the hood of the ol' ford!
__________________
Josiah
  #14 (permalink)
Old 10-17-2010, 04:38 PM
Towmanjbo's Avatar
1992 Ford F-150
Quote:
What a good big brother!!
__________________
Justin
  #15 (permalink)
Old 10-21-2010, 01:12 PM
Onus's Avatar
Onus Onus is offline
1990 Ford F-250
My Garage
Onus is gaining momentum as a positive member of FTE.
Good luck with the project. 300 are cool. I want to get a working one badly for the ole' 83.
__________________
Tanner - Connecticut Chapter Member.
1983 F-250HD 2wd 300. T18 4speed 4.10s. Base. 170k Hiding in garage for the last 10 years. dead. dads truck. Project truck.
1991 F-250HD 4x4 351w ZF 5speed 4.10s Custom. 165k old plow and landscaping truck. Parts truck.
1990 F-250HD 2wd 7.3idi e4od 3.55s. Custom 346k 'The Carpathia' Daily driver.
Tags
150, 1986, 300, 300 build, 32x115x15, 5124b, build, carburetor, choke, coil, cooper, dui, ford, heater, horsepower, live wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
