Transmission pan torque specs? - Ford Truck Enthusiasts Forums
Old 09-22-2010, 11:47 AM
Geardriven77 Geardriven77 is offline
Geardriven77 is starting off with a positive reputation.
I'm changing the tranny filter on my '96 van today and need to know if the pan bolts and the filter bolts need to be torqued to a specified ft-lb. I don't own a torque wrench but may be able to borrow one. TIA
Tim
1996 E150
1983 F150
Lynchburg, VA
Old 09-22-2010, 05:05 PM
danger-ranger93's Avatar
danger-ranger93 danger-ranger93 is offline
danger-ranger93 is starting off with a positive reputation.
i can check my haynes when i get home, they may be in inch pounds.. but i'll check when i get home
Old 09-22-2010, 05:25 PM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
I'm not positive but I think its anywhere from 10-16 ft-lbs depending on the type of tranny.
Old 09-22-2010, 06:12 PM
my haynes says for all auto's its 10-14 ft lbs
Old 09-23-2010, 12:12 PM
Finally got to the transmission filter change today. In the process of taking out the 17 bolts in the pan, one of them rung off in the transmission housing (oh joy). Will attempt to drill out and remove with an extractor. If that doesn't work I'll have to drill one step bigger and tap hole. Also, I found an odd object laying in the pan when I removed it. It's a little yellow plastic piece about an 1-1/4 long with a conical end with an O ring on it. The other end is a 3/16 shaft. I have no idea what it is or where it came from!
Old 09-23-2010, 12:25 PM
jim henderson jim henderson is offline
jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.
That plastic piece is the dipstick tube factory plug. It is on the tube before it is installed into the tranny during assembly. When the dipstick is pushed in the first time it pushes the plug out to float harmlessly in the pan until the next fluid change. This means the fluid in your tranny has never been changed before. Maybe why one bolt broke off.
Be careful while torquing the bolts back into place. Some pan gaskets will squeeze out or cut under the bolts and give you a really good leak. Cork and rubber gaskets seem to do this most. The black "hard paperboard" like gaskets don't have as much problem with that.
If you are using a soft gasket you might want to "glue" it in place and go light on the torque while watching the gasket for bulging. If it bulges, back off a bit on torque and maybe use some gasket sealer on the bolt since it won't be torqued to spec.
Without a torque wrench, hand tight is more than enough. Don't go honking on the wrench.
Good Luck,
Jim Henderson
Old 09-23-2010, 12:46 PM
Thanks Jim. I was speculating that the plastic piece in question must have been dropped or pushed through the dipstick tube since it matches nothing else.
Old 09-23-2010, 01:10 PM
DBGrif91's Avatar
Quote:
One thing I've learned is that, once the bolt has made contact with the surface and is just a little bit snug, one 1/4 turn with a wrench or ratchet from that point is equivalent to about 14 ft-lbs. It's obviously not as accurate as a torque wrench, but it might work for you.
Anyway I could run these wheels and tires? Apocalypse Excursion - King of SUVs 9 08-04-2014 07:57 PM
Whataya think about this chaser1602 1961 - 1966 F-100 & Larger F-Series Trucks 0 07-27-2014 03:30 PM
Need Slick Sixty parts? Ole 64 Virginia Chapter 0 10-12-2013 07:30 PM
1963 & (2) 1965 F100 part trucks 4 sale Ole 64 1961 - 1966 F-100 & Larger F-Series Trucks 0 10-12-2013 03:58 PM
torque specs timf150 Excursion - King of SUVs 2 04-02-2012 04:34 PM
Tags
04, 86, 98, automatic, bolts, f150, f250, filter, ford, pan, ranger, spec, specs, torque, tranny, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
