7.3 IDI injectors
on
Blue is oil
White is superheated (partially burnt) fuel OR coolant
Black is unburnt fuel
Blue smoke all the time indicates bad valve guides and or valve guide seals or piston rings.
And sweet smelling (coolant smell) smoke just indicates you have coolant being burnt, not where it comes from and is not limited to a head gasket.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
For my truck it depends at what point we are talking about; during startup when my glow plugs decide to come on I get very little or no smoke at all, when the glow plugs fail to come on I get a cloud of bluish grey smoke that smells like fuel. once that cloud goes away I usually do not get any really noticable smoke unless you stand at the very rear of the truck and watch the exhaust. For me that tells me along with what I would describe as a lifter noise if this was a gas job, that I have atleast one bad injector. My exhaust is more noticable at night when, i first start off and there are cars behind me.
For you it may be different, it all depends on color, smell, and if you hear any noises that do not sound normal to the engine. this is only my opinion based on what I have learned. the best suggestion I have is post a video, if you can of the smoke and maybe someone can help you diagnose it,
The lifter noise I am talking about is an obvious tick, tick, tick, tick, and does not sound like the clack, clack, clack, clack, they normally make. OK,OK every body can laugh at my description now.
I bought a set from typefour.
The way I look at it is that any/every injector should be pop tested before installation. We all know that just because the package say's 'New'. It just means that You have about an 80% chance of it working as it was designed to.
Russ not only pop tests them, but pressure matches them to within 10 PSI or so. Makes for a much smoother running engine!
Most of the time they come out at 50 to 75 lbs within. And it can be a time consuming pain but well worth it
