7.3 IDI injectors
Old 06-11-2013, 07:06 AM
rjrandy96's Avatar
rjrandy96
rjrandy96 is offline
I would just get the Delphi injectors, thats what im going to get soon for mine. also if you have 4:10 gears(the dually i believe is a dana 60 which should have 4 :10) you can tow your house with that. if you dont have 4;10 gear 6 tons or so if need be maybe 8 but i wouldnt do it all the time unless you dont like your tranny or rear end. iv got a 93 f350 no duallys and it towed and 91 f 150 and a 94 dogde ram out of the mud in 2 wheel with no help from the other truck. did it no problem and its a 5 speed.
  #47
Old 06-12-2013, 12:06 AM
speedwrench72's Avatar
speedwrench72
speedwrench72 is offline
Snapon,,check your crankcase breather, confirm clean and proper operation, before hanging parts,,
  #48
Old 05-04-2014, 11:25 AM
Luke Simmons's Avatar
Luke Simmons
Luke Simmons is offline
I have read a lot of good about typefour's injectors, How do I order a set and how much do I need to save for them?
  #49
Old 05-04-2014, 03:09 PM
88 Ford IDI's Avatar
88 Ford IDI
88 Ford IDI is offline
Look up Typ4 on Oilburners.net. You can find him there. You can also get good injectors from idiperformance.com. Justin's handle here is RacinNdrummin. Both him and Russ are good guys to deal with.
  #50
Old 05-07-2014, 09:48 PM
Luke Simmons
ok Thank you
  #51
Old 10-14-2021, 11:43 AM
newbyto7.3's Avatar
newbyto7.3
newbyto7.3 is offline
HELP!!!
Hey guys I just bought a 1989 7.3L idi that will start when cold (rough start) then once warm if you try to drive it will stall out and act like it’s not getting fuel, I have replaced the injectors, return kit, fuel pumps, tanks, glow plugs, glow plug controller, the battery’s, and more parts in the fuel system but still crank no start and the negative battery cable is smoking/hot
petepetersen
27
07-18-2017 12:58 PM
93idi7.3
23
05-17-2016 05:01 PM
c-hmech
17
09-24-2015 01:55 PM
Dpotts94
01-18-2013 07:10 PM
92F3507.3LIDI
10-28-2007 02:24 PM
Quick Reply: 7.3 IDI injectors
