7.3 IDI injectors - Page 4 - Ford Truck Enthusiasts Forums
7.3 IDI injectors
  #46
Old 06-11-2013, 08:06 AM
rjrandy96 rjrandy96 is offline
rjrandy96 is starting off with a positive reputation.
I would just get the Delphi injectors, thats what im going to get soon for mine. also if you have 4:10 gears(the dually i believe is a dana 60 which should have 4 :10) you can tow your house with that. if you dont have 4;10 gear 6 tons or so if need be maybe 8 but i wouldnt do it all the time unless you dont like your tranny or rear end. iv got a 93 f350 no duallys and it towed and 91 f 150 and a 94 dogde ram out of the mud in 2 wheel with no help from the other truck. did it no problem and its a 5 speed.
  #47
Old 06-12-2013, 01:06 AM
speedwrench72's Avatar
speedwrench72 speedwrench72 is offline
speedwrench72 is starting off with a positive reputation.
Snapon,,check your crankcase breather, confirm clean and proper operation, before hanging parts,,
  #48
Old 05-04-2014, 12:25 PM
Luke Simmons Luke Simmons is offline
Luke Simmons is starting off with a positive reputation.
I have read a lot of good about typefour's injectors, How do I order a set and how much do I need to save for them?
  #49
Old 05-04-2014, 04:09 PM
88 Ford IDI 88 Ford IDI is offline
88 Ford IDI is starting off with a positive reputation.
Look up Typ4 on Oilburners.net. You can find him there. You can also get good injectors from idiperformance.com. Justin's handle here is RacinNdrummin. Both him and Russ are good guys to deal with.
  #50
Old 05-07-2014, 10:48 PM
ok Thank you
7.3l idi injector questions c-hmech Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 17 09-24-2015 02:55 PM
Injector removal and reinstall 7.3 IDI F250 ? petepetersen Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 10-16-2014 09:35 PM
#2 Injector line for 93 idi non turbo Markiv Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 03-10-2014 11:55 PM
ultrapower injectors? brokeasajoke Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 08-20-2013 01:30 AM
7.3 idi injectors and turbo Questions?? Dpotts94 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 01-18-2013 08:10 PM
Tags
1993, 50, 69, 73, 73idi, bb, code, codes, diesel, f250, ford, horsepower, idi, injectors, russ
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
