7.3 IDI injectors - Page 3 - Ford Truck Enthusiasts Forums
7.3 IDI injectors
  #31
Old 09-26-2010, 09:03 PM
91 Super Duty 91 Super Duty is offline
91 Super Duty is starting off with a positive reputation.
Me Too
Quote:
Originally Posted by whenry912 View Post
I may be replacing my injectors soon, what does a pressure matched set go for?
Thanks!
Yeah, great question what does a matched set go for??? Mine are going to be done here real real soon.
  #32
Old 09-30-2010, 02:05 PM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
how can one get in touch with type four and get a set of injectors ?
  #33
Old 10-17-2010, 04:46 PM
typefour's Avatar
typefour typefour is offline
typefour is starting off with a positive reputation.
Thanks for all the interest, now for the suck news, all Delphi suppliers I use are out till at least november. The end not the first, I have 2 sets left but this last order cost me more so I have to add that, they are going from 295 to 343.00 sucks but after this I cant get any more till the warehouse restocks. And I bet those marketing genius's are going to mark up these "obsolete hard to get parts".
  #34
Old 10-17-2010, 09:36 PM
mudbob mudbob is offline
mudbob is starting off with a positive reputation.
That sucks glad I did mine earlier this year. Thanks Russ
  #35
Old 10-18-2010, 08:25 AM
Jim Allen's Avatar
Jim Allen Jim Allen is offline
Jim Allen is starting off with a positive reputation.
Quote:
Originally Posted by fonefiddy View Post
I bought a set from typefour.
The way I look at it is that any/every injector should be pop tested before installation. We all know that just because the package say's 'New'. It just means that You have about an 80% chance of it working as it was designed to.
I agree, though with my engine apart, I decided to check mine. They are Lucas CAV BB code injectors I bought new in '98 (IIRC). They have about 50K on them. Watched them being tested and other than a little bit of chatter with some, they were all popped at 1650 psi with a good pattern and no leakage. I'm going to reuse them. Wish it was as easy testing the pump, but it has the same 50K miles and the truck was running fine before I blew that head gasket.
I guess Russ would be the guy to ask, but I wonder how often new injectors need to be tweaked?
  #36
Old 10-18-2010, 07:28 PM
If Typefour wants to let me us know when he gets more in, I definitely will order a set. Until then I have a clutch fan to replace, not really looking forward to that. I certainly understand him having to pass the increase on to his customers, I have had to do the same with the rising cost of deisel in florida...still can not figure out why it went up 20cents in a week.
  #37
Old 10-18-2010, 10:03 PM
cj06's Avatar
fuel goes up cause of GREED
  #38
Old 10-22-2010, 12:26 PM
1991 F-450 1991 F-450 is offline
1991 F-450 is starting off with a positive reputation.
Did you get the injectors changed?
I an looking into changing my injectors on my 91 super duty. I like working on the truck, but that is a prodject that I have never tried befor.
  #39
Old 10-22-2010, 02:10 PM
I have yet to try it either, I have done alot of reading and it appears to be pretty straight forward. The big thing I have read is to lube the O-rings prior to installation, some say to use motor oil and others say to use vaseline, not really sure which is better. The only thing I am not sure about is the IP timing, again some say you have to adjust it everytime you change injectors and others say not. The one thing everyone agrees on is to change the return lines everytime you change injectors.
One thing that kills me is alot of these shop I have talked to around here just want to replace the bad injector(s) and let it go, they are probably the same guys that only change the bad sparkplugs when they tune up a gas engine, or charge you for putting in new ones with out even taking the old ones out.
  #40
Old 10-22-2010, 11:51 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Quote:
well they do this because modern diesel's fuel injectors are very costly.with the idi though,it just makes sense to change all 8,as it's still cheaper than just 1 injector for a powerstroke.
  #41
Old 10-23-2010, 12:04 AM
wreckinball's Avatar
wreckinball wreckinball is offline
wreckinball is gaining momentum as a positive member of FTE.
easier than changing sparkplugs on my 93 bronco, do not be scared of this project!!! any questions, let me or another that has done it know, it is easy. oh and just simple oil for the orings, but if you have a petroleum jelly lube, get your lube on hahaha.
  #42
Old 10-24-2010, 02:13 AM
polarismuddman's Avatar
polarismuddman polarismuddman is offline
polarismuddman is starting off with a positive reputation.
If you've got any issues just ask like he just said...the injectors themselves are 1" deepweel socket, the injector lines onto the injectors are 5/8's. Don't be afraid to bend the lines out of the way of you getting the injector out GENTLY. I use WD40 to lube the O-rings but oil or vaseline or transmission fluid will all work for that need. The cheapest place I've found to buy the Return line kit is from Pensacola diesel. Been there done this twice and the second time I had an issue.....feel free to ask for help.
  #43
Old 10-24-2010, 09:57 AM
What about having to reset the timing of the IP, is that mandatory or can you just change out the injectors and return lines, start her up and drive? I definitely plan on getting the Viton orings for the return lines when I do this.
  #44
Old 10-24-2010, 02:42 PM
typefour's Avatar
So, when the supplier does get some in I am going to do a large buy and pass the savings on, I will post all info when I get it.
I sell them with a return kit and the vitons are included at no charge.
It is not mandatory to set the timing but it is the best way to do it, also new ones could use a check after 10k or so, if reset then they stay set for a long tome, the springs take a set after a while.
1650 on a used set is great and they will stay at that pressure for a long time. The Lucas CAV injectors were a fine product.
I am working out of town all during the week so pardon me if I am slow to respond, I get one day and the wife gets the other of the weekends.
At least I have a job for a while.
  #45
Old 10-24-2010, 08:57 PM
Typefour, I'll be looking for your post that you have them, I am definitely interested.
7.3l idi injector questions c-hmech Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 17 09-24-2015 02:55 PM
Injector removal and reinstall 7.3 IDI F250 ? petepetersen Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 10-16-2014 09:35 PM
#2 Injector line for 93 idi non turbo Markiv Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 03-10-2014 11:55 PM
ultrapower injectors? brokeasajoke Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 08-20-2013 01:30 AM
7.3 idi injectors and turbo Questions?? Dpotts94 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 01-18-2013 08:10 PM
Tags
1993, 50, 69, 73, 73idi, bb, code, codes, diesel, f250, ford, horsepower, idi, injectors, russ
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
